tomschauer wrote:Source of the post Check your transmission fluid. High trans temp will also give you an alarm
This is a good tip, that I hadn't thought of, and there is no trans temp gauge at the helm.
thanks!
cliff
km1125 wrote:Source of the post Wow, sounds like it very well could have been a tranny temperature issue, with the burned fluid. I'd keep a close eye on that, as the new fluid might allow it to lock up a little more (averting a temperature alarm) but might still slip and wear the clutches, putting you right back where you were but with a worn out transmission.
Viper wrote:Source of the post When was the last time that fluid was changed, and do you know if she's ever had an impact?
bud37 wrote:Source of the post So because there is some discussion about the fluid........when you checked the fluid before you changed it....how would you describe the color on the dipstick.....pinkish,used oil color,or honey color.?
Do you have v drives with the trans/drive ( no shaft between ) attached directly to the back of the engine ?
