Carver Mariner Reviews
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 29 times
Carver Mariner 350 - Boattest.com: http://www.boattest.com/boats/boat_video.aspx?id=88
- Been thanked: 490 times
Re: Carver Mariner Reviews
I think mine is ugly, ugly, ugly. But the layout up and down; how could it be better?? It's a nice boat to take trips on, and easy to pilot, forward. I back into my slip but that rear chair on the bridge is going to be a challenge. I guess I'll just have to watch the port side and judge the rest from there.
I've just about taken the entire boat apart and back together again. Everything is easy to get to, once figured out. It's built well. Plenty of room for anything you;d want to do. I think I am going to enjoy this boat.
Great laker
- Vessel Info: 1986 36 Mariner 3697
Mercruiser 454's - Location: Kenosha, WI
Great Laker. Kenosha
1986 Mariner 3697
Great laker
1986 Mariner 3697
As for thruhulls, I changed all of mine to stainless steel. Most needed to have the holes made larger for the new stainless fitting, so I used a burr to get the hulls to the right size for the new fittings, and then gouged out the coring a bit and filled with epoxy. Then used copiuos amounts of BoatLife Caulk.
I would say at least half of the original fittings were brittle and snapped easily as I removed them.
I also replaced the vent fittings to the newer flush ones.
When doing the thru hulls, if you do them, make the holes the right size as described above, slide the through hull in and tighten the nut, then run masking tape around the throughull right up to the metal.Then remove the fitting and tape the entire surface of the exposed part. Then gob the boatlife on. Reinsert, tighten it up, then wipe the oozed out caulk off, then remove the tape. Beautiful.
