Eurokera Princess glass top replacement for 2004 366 carver Motoryacht
skolmates
Vessel Info: 2004 366 Carver Motor Yacht
Has thanked: 4 times
Postby skolmates » September 19th, 2019, 12:50 pm
I am looking for a replacement glass top for The Eurokera Princess stove on my boat, a 2004 366 motoryacht, any ideas where to find this and best pricing?
Been thanked: 1180 times
Re: Eurokera Princess glass top replacement for 2004 366 carver Motoryacht
Postby Midnightsun » September 19th, 2019, 1:22 pm
Is this an oven/stovetop combo unit or simply a stovetop? i assume you broke the glass and want to replace? Cannot help you on this however I have seen some really neat installations where they inserted an induction stovetop into the existing conventional style glass top. May be worth considering since induction is so much better in every way.Mine was easy as I was able to locate a stovetop just a bit larger so enlarging the counter top hole to suit was all that was required, gotta love the induction.
skolmates
Postby skolmates » September 19th, 2019, 1:52 pm
Midnightsun wrote:Source of the post Is this an oven/stovetop combo unit or simply a stovetop? i assume you broke the glass and want to replace? Cannot help you on this however I have seen some really neat installations where they inserted an induction stovetop into the existing conventional style glass top. May be worth considering since induction is so much better in every way.Mine was easy as I was able to locate a stovetop just a bit larger so enlarging the counter top hole to suit was all that was required, gotta love the induction.
Correct, I just need to replace the glass as it broke- and since is 15 years old maybe it isn't even available? May I ask wht type of stovetop you got and pricing? Thanks again!
darrenlife
Vessel Info: 2002 Carver 410 Sport Sedan
Been thanked: 36 times
Postby darrenlife » September 19th, 2019, 3:18 pm
I replaced my original 3-burner cooktop with this: http://www.trueinduction.com/Triple-Burner.aspx
It's induction so super efficient and only needed to trim 1/4" off one edge
Postby Midnightsun » September 19th, 2019, 3:54 pm
I basically shopped Amazon until I found the closet dimensionally to fit my application. Yours will differ but this is what I bought. https://www.amazon.com/True-Induction-TI-2B-Counter-Cooktop/dp/B0087OWY5A/ref=sr_1_5?crid=2MEZVF6RJ0OPE&keywords=true+induction+cooktop&qid=1568922816&sprefix=true+induction+%2Caps%2C218&sr=8-5
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » September 20th, 2019, 11:57 am
Unless you find a retailer that might have some parts still in stock, you're out of luck as those were discontinued years ago. That division was bought by Whale years ago, then Attwood who stopped making them. Force 10 makes one that's a pretty close footprint to the Princess.
Preferred
Vessel Info: 455 Carver 1998
Has thanked: 6 times
Postby Preferred » July 4th, 2021, 12:40 pm
I did it !! I shattered the glass of our Princess oven door! The stove is 1998 model 23 years old. Time to replace, I see some on this thread
Replaced with an induction top, we would then use our convection microwave as an oven. I have searched does anyone have any more input on manufacturers and models?
