Toilet waste (liquid) exiting out the air vent
- Ozark Carver
- Vessel Info: 1984 Carver 3207 Aft Cabin
All at once when the toilets are flushed no fresh water enters the toilet and the (liquid) exits the boat on the port side
from what I think is the vent tube??
At the same time no fresh water enters the boat when on shore water.---and that's only when hooked up to shore water.
We almost never turn on the water pump nor use the holding tank and up until this recent even had no problem dry
flushing the toilets while under way as we never have put any solids in the toilets at all in the 5 yrs we've owned the boat.
Can anyone see anything obvious in whats happening?
Is it that the toilets only pull fresh water from the holding tanks regardless of being hooked up to shore water?
Tight quarters down there and would love some ideas before I go down and get myself jambed down in there !!
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Toilet waste (liquid) exiting out the air vent
When stuff comes out the vent thru hull fitting, that usually means it is full and needs to be pumped out. If that is the case, it needs to be flushed out and cleaned. First check to see if there is a vent line charcoal filter, in that case it needs to be removed before the flush out. If filter has exposed to stuff or water it will need to be replaced.
Do you get shore water to your taps and other fixtures?
- Ozark Carver
That seems embarrassingly simple and makes total sense. Thank you for the replies and I will confirm this weekend !!
I appreciate it !
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Cooler
Cooler wrote:Source of the post What may have happened is, the last pump out you did, the person pumped out the water tank instead of the waste tank. That's why, all of a sudden you have no water in the holding tank, but your head is still full. The two caps are near each other.er
OMG, if that's the case I would bleach out the potable water system. Can't imagine what might have been on the hose adapter that was screwed into the wrong cap! I never thought about that possibility, but it makes me glad that on my boat the pumpouts are on the port side and the potable water fill is on the starboard side!
- Cooler
- Has thanked: 603 times
- Ozark Carver
All theories were correct in some degree or another.
The sea-cocs were never opened from summarization, as the boat was under gen set removal and replacement over the summer and was overlooked... thus no water was being introduced to the flush system.
The last pump out was not successful back on July as I find out the marina pump out system was not working well.
End result was as described by everyone and 100+% full waste tanks and it just a case of me not even considering they
had not been emptied when I last had the pump out done.
The toilets had been back flushing out the vent as there was just no where else for it to go.
Fortunately the boat's use was very low this summer and had very low toilet use.
All in all things seem to be doing as they should now.
Thanks again for the helpful advise and I am glad I joined this club for sure !!!
(Next is the gen-set continuation of problems which I see are talked about a lot on this site)
Best to all and thanks again !
-Ozark
Users browsing this forum: No registered users and 42 guests
