New Inverter/House Bank
- vineyardgray
- Captain
- Has thanked: 128 times
- Been thanked: 33 times
- Contact:
Re: New Inverter/House Bank
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
This really pissed me off, for a number of reasons:
1. Supposed to be solid equipment. I have not seen mention of this before.
2. I was already irritated because the rest of the Blue Seas stuff has lugs that are perpendicular to the mounting surface, not parallel to it, as these are. This orientation change
results in a difficult cabling situation (see the prior photo of the huge jumpers I was forced to create). I will admit that I doubled up on my cable runs as opposed to buying heavier gauge cable, but the extra long lugs of the Blue Seas remote switch seem to infer that they expect a lot of connections. During final torquing I heard a pop. I was forced to use a socket due to the orientation of the stud and the fact that the housing made back to back lug orientation impossible. I will also admit that I used power lugs instead of battery lugs which I did as I wanted the best installation possible - another reason I selected Blue Seas.
When I heard the housing pop, I had just given a final torque which I felt was necessary as the cable bundle was still easily movable by hand.
I have a second one of these as design plans changed after having purchased them. But now I'm weary of using them until I talk to the manufacturer .
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
There's no way I can mount it without the damn thing falling apart so I leave it hang on the cabling until I can get some 4" screws to hold the whole mess down.
I've also had to hang it upside down due to Lug orientation so I've taken the opportunity to mark it with a Sharpie to clearly show the off position.
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
The Victron shunt that comes with the BMV is clearly not expecting to see Power and lugs that are much thicker than normal battery lug and therefore there's not enough thread
I still need to add the battery negative to this bundle so I need to lose the lock washer in order to make everything fit.
1988 Carver
3867 Santego
PCYC
- Has thanked: 598 times
- Been thanked: 1281 times
- Has thanked: 469 times
- Been thanked: 1765 times
FWIW, it's a good idea to use adhesive lined shrink tubing on all your connections for a few reasons; it helps protect the exposed wire from the elements, it helps stabilize the joint where the wire and lug meet, and it serves to isolate the terminal as the lugs will be a potential short hazard since they will stick out beyond some device covers as noted in the pics. This will be a red flag to a good surveyor. It'll be a pain to disconnect everything again but it's still doable if you get a good quality shrink tube that will shrink at least 3 times it's original size such. Ancor makes a good tube but there are cheaper brands out there that are good as well. I bet that crimper made things a lot easier, I use a hydraulic one.
I trust that you'll secure all the wiring to the bulkhead after you're finished connecting everything?
Viper wrote:Source of the post If the shunt is in the circuit that requires two pos and two neg cables to carry the max load, then it must be wired that way through the shunt as well.
The victron shunts that I have installed are always in the black ground cable between the battery bank and the engine block / ground point......I don't understand why you would need two cables on each end of the shunt itself as it is only in the ground cable.
