454 Crusaders. Starboard will not go forward but will go reverse
- Gazookas
- Vessel Info: 1983 Carver 3607
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
Re: 454 Crusaders. Starboard will not go forward but will go reverse
Others here with more knowledge will be able to help. The black transmission fluid definitely scares me that it is something serious. Good luck.
2022 Stingray 182 SC
- Has thanked: 78 times
- Been thanked: 1093 times
If you're really handy it's not too bad of a job to do. I did mine (also a 3607) about 25 years ago. The worst part is getting the trans and reduction gear out. I pulled them apart to help alleviate the weight.
A couple things you can check first though. One is a line pressure test (screw a gage in one of the top plugs) and the second is the screen at the bottom of the case. IIRC, you have to remove the lower hose and the fitting down there and pull out the screen inside. The screen may be plugged up (but that would probably affect reverse as well).
Also, check the cable adjustment and make sure it's PROPERLY going into the FWD and REV positions... it could be a bit off and only PARTIALLY going into FWD but enough into REV that it's engaging.
- mjk1040
- Been thanked: 246 times
- Has thanked: 469 times
- Been thanked: 1765 times
Don't know which unit is being used here but if it incorporates a filter, the pump would be affect by a filter restriction in both fwd and rev, but you never know, I've seen stranger things happen.
Do you get shaft creep - shaft turning even when she's in neutral?
Keep us posted.
- Pit stop
- Vessel Info: Trojan / Carver 370 express cruiser with twin 454 XL motors , velvet drive tranny's Walters "V" drives
Sorry
Eric
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 20 times
I've researched and found that most of the cases of "trans" issues are related to "port" trans, operated in "reversed" mode. Things that make you go Hmmmm? Replaced trans, every thing working great!
I have the original trans, and will attempt a "rebuild" in the future as it only had 239hrs on it.
