2000 Carver 404 Survey - Percussion Test Failure
- Briangates
- Vessel Info: 2007 Carver 41 CMY
Twin Volvo D6 - 370hp - Location: Victoria
The owner said that he has recently resealed the windlass and also where the base of the rails attach to the deck to prevent any further intrusion of moisture.
I have read that finding moisture in the core on a deck isn't uncommon with an older boat.
It doesn't appear to be serious and there are no signs of moisture coming through the deck into the cabin. Al of the material lining the roof and sides inside show no staining whatsoever.
I have seen videos of replacing damaged core from inside the vessel and I am really not too interested in taking on this type of repair as it looks difficult and expensive to do correctly.
So does anyone have any experience with moisture found in their vessel? I am thinking it is probably something owners do not openly discuss or are unaware that their vessel may have taken on moisture through one of the various attachments to the fibreglass.
Any thoughts on whether this is a deal breaker would be appreciated.
- Has thanked: 469 times
- Been thanked: 1765 times
Re: 2000 Carver 404 Survey - Percussion Test Failure
Is it a deal breaker? Get an experienced fiberglass tech to assess and report. Based on his findings, get him/her to quote the repair but keep in mind that the condition might be worse once they start the work and dig deeper. Then decide from there if the boat is for you. Remember though that chances are most boats you check will likely have those same issues in varying degrees. How much you're willing to put up with depends how much of your time you're willing to spend on repairing it yourself or how much you're willing to pay someone else to repair it for you.
Good luck and keep us posted.
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
- Has thanked: 598 times
- Been thanked: 1281 times
Really to make any qualified decision as far as deal breaker status, the extent, amount of moisture etc needs to be known and like has been said anything can be fixed. A boat here recently had maybe 10% of the side hull wet ( not a Carver), all fixed now and you can't tell..guy did a great job !......that boat was much , much newer than the one you are considering.
Like I am sure you already are aware, 20 yr old boats are going to have moisture somewhere, after all they are not new any more....as always good luck with it....
- Briangates
While I was on the boat we had a pretty good downpour of rain and I notice areas on the front and side decks where it appeared that the water had not dried and the deck remained wet in larger areas. Near the bow pulpit and windless pedals.
I am going to discuss the water meter readings with the surveyor as none were written on the report.
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
Good luck to you as you move forward.
2022 Stingray 182 SC
- Cooler
- Briangates
It looks like there's enough areas of concern that will require further assessment and hopefully there's only isolated areas requiring core repairs rather than the whole deck. Either way, in the end, you'll be better off redoing all the non-skid so isolated repairs aren't noticeable. I would insist on that if you go ahead with repairs.
Has the surveyor expanded on his findings yet ?
