Small 300 to 700 watt pure sine wave inverters
Re: Small 300 to 700 watt pure sine wave inverters
- Has thanked: 602 times
- Been thanked: 1310 times
Anyway thanks for the input, I think I know what and how I am going to do this install now.....
Now it seems for me to be more about getting a unit with a quiet fan, not sure whether a larger unit designed for big loads would meet that criteria or the smaller units will as well.....opinions always welcome..
Can't seem to leave it till next spring..
If you don't need to power anything else with this inverter, keep it small and it will not have fan noise.
I use 100 watt inverters for each of my tv's (24"). I think they were less than $25 each. No fans, no noise, no issues.
I also have a 2500 watt inverter near the breaker panel incase I need to run larger loads, but I have only used it once, to make sure it worked.
I just fire up the genny for coffee, oven etc.
Just my 2 cents.
Tend to follow suit on other items as well looking for items that work off of 5v which is USB. Cut the cord and into usb as opposed to wal wart 110 to 5v. This allows items to work off of standard 12v power. Harmony remote chargers are like this as well my projection clocks.
There will be three things attached for now, the dvd/blueray thing ( have three of them already, don't ask ), antenna booster, and the tv. I really need the booster where I am as there are only two stations on a good day.
As a result of all this searching I may pick up one of those watt meters as well....could be handy.
bud37 wrote:Source of the post So far I was not able to find a 32" tv that has the inline transformer. The benefit of having the inverter I think for me is the fact that I can shut down all the devices attached to it with one switch/breaker. One interesting fact I did come across was one of the inverters with two plugs actually split the output, half for each plug , something to check. For now I am down to two units, although that could change at any time...![]()
Same for my 27" and then I had the issue of the Bell ExpressVu sat receiver which is 110v so the small inverter worked out well for this and allowed me to also add a Bose sound bar (110v) and a few other small items. Heck, even have a small sub (110V) behind the TV.
Unfortunately the MM6 Mirage is discontinued, awesome small sub. https://www.amazon.ca/Mirage-MM-6-High-Performance-Discontinued-Manufacturer/dp/B001HRFINY- bud37
Here, what do ya think....
