New Inverter/House Bank
- vineyardgray
- Captain
- Has thanked: 128 times
- Been thanked: 33 times
- Contact:
Re: New Inverter/House Bank
1988 Carver
3867 Santego
PCYC
- Has thanked: 602 times
Getting extra into those cabinets is interesting, I am still bleeding from the other day.
- vineyardgray
- Captain
- Contact:
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
. Lessons Learned:
1. Tough project. I can't imagine being an Installer for a living. Not only was lots of tight space "yacht yoga" involved but the learning curve and tying everything together was a lot more difficult than it seems on the surface. Let's just say my mettle was tested.
2. If you have the option between "saving money" by using dual 1/0 versus 4/0 - save yourself the trouble and go 4/0. Having to offset the lugs on the 1/0 caused me no end of headache.
3. The battery monitor is an awesome and necessary device even if you don't install all this other crap™
4. Having the right tools and lugs makes all the difference. Making the battery cables was a breeze because I had the hydraulic to borrow - if I had to have these made elsewhere it would have slowed my tortoise like progress even further.
5. Along the same lines as point 4 - Marine cable is tinned and finely stranded and as such is considered Flex cable so don't go to your local electrical wholesaler and expect number 6 AWG butt splices to fit very well even if they say they are meant for stranded cable. Same for ring terminals. Let's just say I figured this out the hard way.
6. Hole saws are measured OD (outer diameter) and electrical fittings are sized ID (inner diameter) thus an electrical fitting of 1-1/2" will not fit in a 1-3/4" hole.
7. Just because it looks like a cable raceway goes in one direction doesnt mean it actually does. Carver sure made some head scratching design choices much to my amusement and irritation.
Thanks all for your comments throughout the process. I think writing this kinda kept me on track.
1988 Carver
3867 Santego
PCYC
vineyardgray wrote:Source of the post The ferrules look like they would have helped - do you use them without crimping them?
I had a few around from the olden days...
.....what seems to work is to fit them to the wire size ,slip it on then heat shrink it in place....slip into the connector and tighten the screw...the act of the screw tightening down will pinch/crimp the ferrule for a perm attach which holds the wire in place nice.Gotta get some more, amazon seems like the only place...there are no suppliers around me here that carry these things.You could fab em if really pressed but I will just order some.....
- vineyardgray
- Captain
- Contact:
8. Have a look at where all the heavy stuff is already installed on your boat (fridge, stove, icemaker) and install your new 400lb battery bank and 60lb inverter/charger on the *opposite* side (unless you _want_ your boat to list like a bastard
1988 Carver
3867 Santego
PCYC
Thanks for sharing with everyone along the way and I'm glad you can finally kick back and ponder your next project
- vineyardgray
- Captain
- Contact:
Viper wrote:Source of the post proper planning is key to saving time and ending up with a safe system
Amen to that - I started planning this stuff last year! Bought a charger only then a charger/inverter came up so switched gears... Reading all the blogs and manuals and like you say - the system integration was quite complex.
Ha - I already have a number planned
1988 Carver
3867 Santego
PCYC
- Marty
- Vessel Info: 2000 326 AFT Cabin
- Has thanked: 16 times
- Been thanked: 9 times
Cheers
