refrigerator
- henry
- Vessel Info: 1987 carver mariner 32 ft
refrigerator
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 4 times
Re: refrigerator
Have you pulled off the bottom plate on the front of the refrigerator? I am just guessing on this but it would seem likely. I'll check mine but won't get there until the weekend, maybe.
Steve
- Has thanked: 59 times
- Been thanked: 479 times
Re: refrigerator
I know he replaced it twice. The first new one did not come with an extra cooling kit, and it ended up frying itself in the closed cabinet.
The second one he bought, he bought it with the fan and also installed a second vent in the side wall, or maybe the back wall in the side bedroom.
So, however you do, buy the extra fan and add an extra vent.
- henry
Re: refrigerator
Re: refrigerator
I did a changeout on my 42, but it was a full size refrigerator. I removed all visible fasteners holding it in, and it would not budge. Nobody could tell me where the "hidden" screws were. I took panels off, I climbed underneath from the engine room side, and I could not find those darn hidden screws.
Well, there weren't any. It got to the point I decided there were no hidden screws; it was just stuck in there. I just had to pry the fridge out, because it was stuck to all the wood after all those years. I literally stepped back and body slammed it. It came loose from being stuck to the bottom.
If you removed all the visible screws, yours may be stuck like mine was.
jaysmariner
- Vessel Info: 1986 Carver Mariner fully equiped and well kept
Re: refrigerator
As waybomb indicated I did indeed replace the refrigerator twice. THe removal as I recall (16 years ago) was pretty straight forward. Removed front flange screws and slide out. Wiring had plenty of slack.
If you are replacing the unit with another Norcold unit ,several things will need to done.
THe height and the width should not be a problem , however the depth of the new unit was (at least for me) was greated then the old . You will have to provide a wood spacer about 1 inch square as a spacer to put between the new flange and the face of the cabinet frame the old refigurator screwed to.
AS Waybomb said, make sure the new refrigerator has a cooling fan.
THe old refrig had two compressors the new will only have one.
I also cut two 4 inch by 12inch holes in the back of the refig cubicle. THe holes will end up to the left of the bunk room closet about 6 inches from the floor and 12 inches from the ceiling.
This combination of openings and the existing opening in the hallway will provide plenty of circulation.
I did not have a cooling fan nor the extra openings and my second refrig lasted two years. My third ( with fan and openings) has lasted 14 years(knock on wood). Hope this helps . Jay
- henry
Re: refrigerator
- garytheguard
- Vessel Info: 1989 Carver 3807
- Has thanked: 3 times
- Been thanked: 2 times
Re: refrigerator
1989 Carver 3807
Thunder Bay, ON, Canada
Re: refrigerator
I need both doors. The fridge works fine otherwise.
finole
Re: refrigerator
So I think the gauge of cord and length could have an effect on the operation of a compressor. I would think you need a 14 gauge cord.
Users browsing this forum: No registered users and 154 guests
