Need replacement Rub Rails for 1983 Carver 3607 Aft Cabin
Skydancer
Vessel Info: 1983 Carver 3607 Aft Cabin
Twin Crusader 350s (454 cui)
Has thanked: 109 times
Been thanked: 4 times
Postby Skydancer » November 18th, 2019, 6:11 pm
Does anybody know of a resource for replacement Rub Rails for a 1983 Carver 3607 Aft Cabin? I need to replace mine all the way around (looks like the previous Operator played bumper cars with the yacht).
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Re: Need replacement Rub Rails for 1983 Carver 3607 Aft Cabin
Postby Cooler » November 18th, 2019, 8:17 pm
You should be able to order rub rail from any decent marine store. They should have a big sample chain of 30 different types to pick from. Otherwise, if there is a boat salvage yard in your area, you could check that out. Trouble is, most salvage yards don't really save much in terms of value. Lower price yes, but bent up rub rails also. 8-) er
Cooler By The Lake
Postby Viper » November 18th, 2019, 10:42 pm
You can also try contacting Carver with your hull number and they'll give you the part number and supplier info for your particular rub rail.
Been thanked: 1111 times
Postby km1125 » November 19th, 2019, 4:37 pm
I should probably replace mine too, but that's further down the list than some other stuff (like redoing the heads and waste tanks).
Skydancer
Postby Skydancer » November 22nd, 2019, 1:27 pm
Thanks everyone for the responses.
Using your suggestions, I have landed on just the Rub Rail I want.
Much appreciated!
Postby km1125 » November 22nd, 2019, 2:06 pm
You should post what you found and the sources, just in case others ( :) ) might need that info in the future!
Skydancer
Postby Skydancer » December 29th, 2019, 12:12 pm
I found a generic rub rail that will work fine. West Marine
