1977 Carver Santa Cruz 2566
Re: 1977 Carver Santa Cruz 2566
I assume you are diving off shore in SC?
- Diver Tom
- Vessel Info: 1977 Carver Santa Cruz 2566
- Has thanked: 2 times
- Been thanked: 2 times
I suppose anything can be done if structural and safe handling concerns are addressed but that model would not have been the design of choice for that application IMO. Sounds like you're already committed so it may be a moot point but consider that the retrofit will also change the designed USE of the vessel and limit your market if and when you ever decide to sell her.
Cutting the transom is doable if done right. Remember there is a sterndrive hanging off the back that puts a lot of additional stress on the transom while underway. Adding a swim platform and the type of use you're considering will increase that stress as well. If the structural integrity is compromised, it could have dire consequences. I trust you had a survey and the transom checked out with no red flags? The transom on a sterndrive application of that vintage is always a concern to begin with, if there are issues, you'll need to get those assessed and addressed first.
Might be different in your jurisdiction but likely still applicable for insurance; are you licensed to use her as a passenger/commercial vessel?
Good luck with your project.
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
“Escape Plan”
Murray, KY
- Diver Tom
Looking at a side ladder with a carolina rig.- sdsurf
- Vessel Info: 1977 Carver 2276
- Has thanked: 5 times
- sdsurf
