Carver, Sundance, or Bayliner
- Dgessler8944
- Vessel Info: 1986 2757
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
Re: Carver, Sundance, or Bayliner
Whatever you do, spend the bucks and hire a qualified surveyor to check the boat out.
There is a process in buying a boat like this. If not familiar, come back and ask for advice.
- buster53
buster53 wrote:Source of the post While I'm a fan of Carver's, they are hardly considered the Cadillac of boats. They really are a Chevy. I've never been on the Great Lakes, not sure I want to be bobbing around Lake Michigan in an older, $6000 boat. While I agree that Bayliner's aren't top level, I'd lean towards the boat with the best cared for engine and drive. Make sure the boat has a decent amount of HP for the size and weight of the boat. It can happen with any brand, but Bayliners are notorious for coming out of the factory, underpowered from the get go.
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
None of the Bayliners I owned were underpowered. That reputation is not entirely without merit. For instance my 2450 Ciera had a 305 V-8 for power but the standard engine in that boat was a 4 cylinder definitely underpowered. All my Bayliners had V-8 engines so they were powered well.
You said you plan to boat on Lake Michigan size will matter. Lake Michigan is an inland sea and conditions can get challenging. Anyway check them all out. Once you decide as suggested already a survey and sea trial are a must. Good luck.
2022 Stingray 182 SC
- pepmyster
8.1 Volvo Penta
- Has thanked: 487 times
- Been thanked: 206 times
- Been thanked: 1180 times
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
- Has thanked: 598 times
- Been thanked: 1281 times
Older 5K to 7k boats may be ok for smaller calm bodies of water where shore is right there. I would not be taking anyone/family out on big water with boats like that, there is just too much at stake, even with larger/heavier boats.
Consider surveyors, etc, etc before any purchase like this makes sense for your intended use. Now there will always be gems out there, just be aware to be careful....the boat maker really has no play in old boats, they have probably been owned by far too many people.( read, all kinds of alterations , good and bad ).My guess here is you are considering these brands based on purchase price......good luck with your adventure.
- Been thanked: 601 times
Carver is or was owned by Genmar Marine which also shared building facilities with many other "brand names " under the genmar umbrella.
That being said, do a bit of research on the models and years you are interested in.
as mentioned in previous posts, many of the older boats had cored (wood between fiberglass) hulls, transoms and stringers. As the boat ages, crack in the fiberglass, poor assembly practices and owner DIY projects allow water to infiltrate these areas. This caused rot, that can be repaired, but is often more costly than the value of the boat.
I owned and loved a 1988 carver 2757. In 1999 I had to replace parts of the starboard stringers due to water intrusion at the motor mounts. Also, mine had the mercury 3.7 LX engines, if the one you are looking at has the 3.7's, stay away, as parts are hard to come by and very expensive these days. With 1200 hours on those engines you are on borrowed time.
I guess this is a very long winded way of saying, do your research ask questions and don't be swayed by a low initial price. Boats are great, but structural problems are very expensive to repair. If you can find a boat a bit newer that you know has no wood, at least below the water line, I would move in that direction.
As far as the great lakes, you do not mention the models of the bayliner or searay, but if you are talking all 27's I would be much more comfortable on the carver or searay. I believe both the carver and searay of those years (87 ,88) were 10"6 beam boats and weighed about 7000 -7500 lbs. The newer (94) bayliner I think was 8'6" beam and about 5000lbs. (please verify)
