Filter Recommendations
- Peter3607
- Vessel Info: 1998 Carver 500 CMY
1989 Carver 3607 Aft Cabin - Location: Ontario
- Has thanked: 29 times
- Been thanked: 2 times
Mercruiser 7.4L Blue Water Inboard Thunderbolt IV Ignition (gas)
What is the manufacturer's recommended oil filter and fuel/water separator filter?
Kohler Generator
Model 785R63 (I think)
7.5kW Single Phase 60 Hz
Looking for same manufacturer's recommendations as above.
Thanks!!
- Been thanked: 601 times
Re: Filter Recommendations
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
As far as fuel/water filter, kinda depends on what kind of filter housing is there now. Probably best to use what is there now.
- Been thanked: 1180 times
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
erhttps://www.marineengine.com/parts/parts.html
- Has thanked: 78 times
- Been thanked: 1093 times
I've used Mobil1 and Sierra mostly.
km1125 wrote:Source of the post I stopped using FRAM for anything when they did those tear-down analysis several years ago. Don't know if they every resolved the construction problems or ever moved away from the cardboard interiors.
Time flies as that tear down thing you refer to goes back probably 15-20 years and like they say, don't belive everything you read on the internet.
Fram is the largest filter manufacturer in the world, no way can they produce stuff that would be inferior and wreck an engine. They are all built largely on the same principle. Can, filter media and a bypass
- Has thanked: 469 times
- Been thanked: 1765 times
Same goes for many who would not be caught dead using and after market filter or oil for that matter. Bottom line is you need to have a warm and fuzzy feeling based on your decision.
This is a very long video, definitely not scientific but does give you a really good idea of what is inside many of the brands. Oddly enough the end results were the best filters were Fram Ultra Synthetics and Wix Synthetic but this is just based on materials and construction.
Users browsing this forum: Majestic-12 [Bot] and 14 guests
