Carver 466
Happyours2
Vessel Info: 2001 Carver 466 Hardtop with Volvo's
Re: Carver 466
Postby Happyours2 » March 11th, 2020, 7:14 pm
Hi, and thanks for the response. As you mentioned, he said it could be repaired and estimated $5K. unfortunately the crack perfectly outlined the pad of the stand which had been repositioned and you could deflect the area upward with moderate hand pressure. The vessel supposedly settled into soft soil while on the stands or from the looks of it perhaps the stand got frost heaved upward into the side. it has me wondering if the Pasco warnings about thin Carver hulls should have me walking away from the deal.
Re: Carver 466
Postby Viper » March 11th, 2020, 9:15 pm
Under the right conditions, that will happen to any brand. I think the bigger question is whether the yard did their due diligence at inspecting the stands periodically as should be done while any boat is on soft ground that will move with differing temps. I don't think any hull is designed to have the entire vessel's weight supported on a one square foot area of a jack stand. Unless someone qualified can tell you for a fact that there was a structural failure simply due to design or fabrication, I'd say it was due to improper blocking or the lack of regular adjustments, or a previous impact repair gone wrong. Good luck and keep us posted.
Re: Carver 466
Postby Midnightsun » March 12th, 2020, 5:45 am
Sounds like the jack stand was improperly placed plus a combo of soft ground under the keel which contributed to the failure. The jack stand is always positioned on the edge so it partially sits on the chine which has a heck of a lot more strength than anywhere inwards of the chine. Is there damage to the chine?
Re: Carver 466
Postby Viper » March 12th, 2020, 6:33 am
Midnightsun wrote:Source of the post Sounds like the jack stand was improperly placed plus a combo of soft ground under the keel which contributed to the failure. The jack stand is always positioned on the edge so it partially sits on the chine which has a heck of a lot more strength than anywhere inwards of the chine. Is there damage to the chine?
+1
I trust that if you buy the boat, you're not the one paying for the repair?
Been thanked: 1310 times
Re: Carver 466
Postby bud37 » March 12th, 2020, 8:42 am
Happyours2 wrote:Source of the post Hi, and thanks for responding, he said it could get fixed for around $5K. you could deflect the crack area with some moderate hand pressure which has me wondering if the Pasco warning about Carvers having thin hulls should have me walking away from the deal. The vessel reportedly settled on the stands while on the hard (soft) ground. One rudder post support which was glassed onto the hull popped as the boat settled downward apparently and the forward stand pad somehow tore into the hull.
There is always more, isn't there... :-O .......have someone that really knows boat structure have a good look at this before you continue, as there can be other damage hidden that may not show up for a while.....good luck man and be careful.
I agree with the others, you can destroy any manufacturers boat with incompetent yard practices. Boats are designed to float not sit in parking lots or yards, that is why extra care must be taken.
Been thanked: 1111 times
Re: Carver 466
Postby km1125 » March 12th, 2020, 5:50 pm
I agree with the improper stand placement. Should be on a chine or under a bulkhead or (large) stringer.
But it most likely can be repaired in 'like new' condition with a good shop.
Happyours2
Re: Carver 466
Postby Happyours2 » March 20th, 2020, 10:02 pm
Thanks for all the support, bit the big one today and won the bid. Once the wife and I get a week of cleaning done perhaps we will be ready to pronounce being proud owners. But, really we are we got bit by the bug 5 years ago and are looking forward to setting sunsets from our new to us 466 Hardtop! Some new canvas and we'll be looking sharp!
Re: Carver 466
Postby Viper » March 21st, 2020, 8:49 am
That's awesome, congrats. You're going to love it. :down:
Been thanked: 470 times
Re: Carver 466
Postby RGrew176 » March 21st, 2020, 11:54 pm
Looks like happy ending. Glad for you. Good luck with the new Carver.
Happyours2
Re: Carver 466
Postby Happyours2 » November 1st, 2020, 10:07 am
Lyndon670 wrote:Source of the post Where is this boat? I put an offer in on one that sounds like the same #of hours before I bougght my 506, and it failed the survey.
Lyndon, That is a sweet looking 506, wow! The 466 was at Marina Bay Quincy MA and I believe it was the same boat you had surveyed. Needless to say I guess my survey wasn't as thorough as yours because I swallowed the hook line and sinker. With $20+K of rudder and hull work and some pricy engine repairs we managed to get the boat up to Hampton NH and enjoy some wonderful sunsets before pulling the boat last month. I'm still dealing with some vibration issue portside and I'm curious to know what your survey may have uncovered? Thanks,
