Hello from the Tampa, FL area!
- Dark Horse
- Vessel Info: "Dragonfly"
2001 Carver 350 Mariner
Twin 350 MAG MPI - Location: Hudson, FL
- Has thanked: 1 time
- Been thanked: 6 times
My wife and I are moving up to a 1998 350 Mariner Aft Cabin from our Bayliner 2655 Sunbridge. Well, we are still in process - subject to survey and sea trial, which will happen shortly. and then transport to Hudson, FL.
Been in boating my whole life and this will be boat #7 for us. Probably the last one, but i keep saying that!
Any advice on Carvers in general, or this model in particular, would be very welcome indeed! Any issues with the 350 Mercruisers (approx 435 hrs)?
A step up for us in length, beam, and weight (and comfort), but we're very excited!
Cheers!
Steve
2001 350 Mariner w/ 350 Mercruisers
Home Port - Hudson, FL
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
Re: Hello from the Tampa, FL area!
2022 Stingray 182 SC
- Has thanked: 469 times
- Been thanked: 1765 times
The Mercruiser like many other brands are GM blocks marinized with marine hardware. There's pros and cons to each brand but perhaps the best thing about Mercruiser is that parts are readily available and you can get them just about anywhere.
Hope everything works out Steve. Keep us posted.
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
- Has thanked: 64 times
- Been thanked: 481 times
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
You do not state if yours in fuel injected or has a Rochester Quadrajet carburetor. In 1998 I would assume FI, but have seen carbs too. Q-jets are nice carbs with good fuel economy until the big secondaries open. But Q-jets are a pain to work on - one of the hardest carbs to overhaul IMHO. Make sure you pay attention to replacing the fuel filter and water separator to keep the carb clean and prevent problems. And don't run fuel with ethanol on these engines! If you have carb problems, your best bet is to replace it with a quality rebuild and not try to take it apart and fix it yourself. There are several companies that specialize in Q-jet rebuilds and offer a 1 year warranty.
One quirk with some Mercruisers is a 143-147 degree thermostat (not a misprint). This was used on some closed cooling systems to prevent salt build-up in the heat exchanger. Some folks change them out to 160, but others believe Mercury knew what they were doing and stick with 143.
Other than that, just the usual stuff - oil changes, filters, sea water impellers, etc.
Good luck and see you on the water!
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- Been thanked: 601 times
I believe it has been 10% ethanol since around 2005 here. Knock on fiberglass, I haven't had any issues. I never fill up in the spring until I know the marina has received a new fill for their tanks.
- Dark Horse
That being said, over the weekend we looked and and made an offer on a 2001 350 Mariner with almost all the options checked off. It's in fine shape with a pair of 350 Mercruiser MPIs and over all in really nice shape or at least will be after a good cleaning and detailing.
So still in the game...........
- RGrew176
