Swim deck ROT
- Gary Rose
- Vessel Info: 2000 356 carver aft
- Has thanked: 5 times
- Been thanked: 3 times
Swim deck ROT
I
- Been thanked: 646 times
Re: Swim deck ROT
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Swim deck ROT
I wouldn't say it's a problem with that boat/model in particular. It's a problem on ANY brand/model if hardware mounted to the platform isn't properly sealed.Gary Rose wrote:Source of the post .....I hear this is a common problem with this boat....
If the wet core is isolated to the fastener holes then it's an easy fix as g36 explained. It can however be difficult to tell how widespread the damage truly is. An experienced tech with a moisture meter can take some readings and sound the area. Based on their findings they should be able to lay out the area that's affected.
If the damage is indeed widespread, you'll have to cut out the top layer preferably in one piece, and replace the core then reinstall the top glass layer. You can then re-nonskid the entire platform top or just cover the top with SeaDek or a similar synthetic product as doing so will reduce the amount of glass finish work required.
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Re: Swim deck ROT
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Re: Swim deck ROT
Re: Swim deck ROT
++1g36 wrote:Source of the post The swim platform on 355/356 405/406 is not a single layer swum platform it is a 2 part molded into the hull and top deck sections and then finished together when the parts are adhered together.. There is a apx. 6-8" void between the upper and lower sections. So what the issue is with the oem rot is the damage to the upper part. He would not reasonably be able gain access from the bottom for a repair in this case. If its a widespread area it will have to be a repair from the top. He would have to cut out the bottom part of swimplatform and remove to even gain access to the underneath part of the upper platform. If it was a solid added on platform the repair would be a lot different.
- Gary Rose
Re: Swim deck ROT
Re: Swim deck ROT
Re: Swim deck ROT
- MarkMaunder
- Vessel Info: 1990 Carver 27 Santego
Volvo Penta 740
Duo-prop - Location: Fifty Point Marina - Grimsby ON Canada
Re: Swim deck ROT
