530 Voyager Davit Questions
golgi
Vessel Info: Carver 530 Voyager Pilothouse
Has thanked: 19 times
Been thanked: 6 times
Postby golgi » May 6th, 2020, 8:16 pm
Hi all, I have a 2001 530 with a Besenzoni hydraulic davit lift. Two questions... Do you know the max weight that the crane can safely lift? Second, what is the max weight that can be safely stored on the cockpit roof?
Sorry, I'm away from my manuals and I can't find the info online.
Thanks!
Been thanked: 1310 times
Re: 530 Voyager Davit Questions
Postby bud37 » May 7th, 2020, 6:55 am
Do you remember the model number of the lift as there are various ones.
Turtle
Vessel Info: 2001 carver 530
Postby Turtle » June 27th, 2020, 11:13 am
I am looking at purchasing a carver 2001 carver 530 . I talked to carver and they told my max for flybridge they recommend is 600lbs but they said the crane will probably pick up 800 lbs , depending what crane you have . The one im looking at also has a bad ac compressor . I saw previous post about compressor , how much and how big of a pain was it to replace ? This ones salon ac is out . I can not find anyone to get a rough est on how much to fix it , since its not my boat yet and have no access to it .
swaterbly
Vessel Info: Change "N" Course - Carver 530 Voyager Volvo TAMD122a-P
Postby swaterbly » May 9th, 2021, 6:05 pm
The salon unti is the larger unit of the four. A replacement unit is around 2,500 dollars from Airmarine
Postby tomschauer » May 9th, 2021, 7:02 pm
Most of those bigger Voyagers have remote compressors. If the unit is original, it will be an R-22 unit. You will need to replace both the evaporator unit that is in the salon and the remote condensing unit that is in the equipment room. If I am correct, it will be a fairly expense repair.
