Shipping a 2007 42SS-remove superstructure?
- JediJD
- Vessel Info: 2007 Carver 42SS
Woodstock, GA - Has thanked: 1 time
I suspect the correct answer is...pull the boat and measure. However, I'm 750 miles away and hope I can at least start with institutional knowledge. Thanks!
Charles Robertson, USCG Master Cpt.
Woodstock, GA
Prospective Owner of a 2007 Carver 42SS
Current 2003 Sea Ray 380
*All normal disclaimers...I am new to this forum...I may be a complete moron...I read the FAQ's and tried unsuccessfully to search...not holding anyone responsible just asking for opinions...etc. etc. etc.
Lakes Allatoona and Lanier, GA
'07 Carver 42SS "A Little More Nauti"
(tender is a '15 VX Cruiser "Littler Nauti"
'03 Sea Ray 380DA "A Little Nauti" (sold and missed)
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: Shipping a 2007 42SS-remove superstructure?
T-Merc 350 Mag MPI (300hp)
- JediJD
- Been thanked: 490 times
Better check that! And that would be on the trailer. Figure at least a foot between the keel and the street.
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- Ramsport47
When the buyer of our 4207 took it they had the fly bridge off in a day and they left the next day.
BobWaz
- Vessel Info: 1995 Carver 380 Santego 330 HP Crusaders
- Hugo
- Has thanked: 2 times
- Been thanked: 23 times
These boats are designed to be taken apart. The hull will go on one truck and the superstructure will go on the other truck. It's pretty straight forward.
If it were me I would go by water if possible. Where do you boat in Atlanta? I didn't know there was water there...
- JediJD
I'll give Joules a call. The last quote I got was 80 hours of labor to take the cap off...from a marina who apparently didn't have the same insight that you guys do...or figured I didn't care. Either way, I'm thinking I'll get the boat to the marina a couple of days early, pull it, put it on the hard, pull the props and rudders (maybe shafts), do some minor maintenance, flush the heat exchangers and get a careful measurement. In our test measurements...using 19'5" as bridge clearance and 3' as minimum draft, I need 84" from the top of the light to the top of the dash (barely protrudes over the windshield) to clear 15'6". We are measuring 82". I'll have to see if we have any gain from pulling the running gear. If not, she come apart.
