396 power steering
- 650Guy
- Captain
- Been thanked: 40 times
Re: 396 power steering
Oh boy, as I am on the boat now, I went right up and added fluid to the port by the steering wheel. I have not found the reservoir just yet. So I added fluid but found the steering to the left to have not improved. I can turn from center to right very easily, but can only get 1 turn to the left before it feels as it has come to a loss of fluid.
Could this be the "Air"?
I'm so sorry, I'm so new to this system? Or should I say, issues to this system.
- 650Guy
- Captain
Good News: No mess! took a bit of fluid, not a ton, but did take some.
Bad News: She still turns very nicely to the right, but only gets about 1/4 of the way to the left before becoming difficult?
Could that be the "Air" in the system? or PSI?
Sorry, I'm new to this system... or should I say issues to this system.
- 650Guy
- Captain
Good News: No mess! She took a bit of fluid, not a tun, but did take some!
Bad News: still tough to turn to the left. Right is nice and smooth, but left gets 1/4 of the way and becomes difficult.
I'm new to issues with this system, I'm digging around for the reservoir but have not yet found it, also not sure how to increase the PSI.
- Has thanked: 474 times
Sometimes getting the air out of a manual system takes a while. There are bleeders on the steering ram hooked up to the rudders for this but you can accomplish the same thing by turning the wheel back and forth. Sometimes it can take quite a few turns back and forth to get rid of all the air in the system.
I trust you have only one station correct?
I'm also assuming there is nothing by the transom stored in the bilge that might be interfering with the movement of the rudder in one direction?
- 650Guy
- Captain
I only have 1 station. I'm still looking for the canister, but cannot find it either in the engine bay or at the stern, but as I say, still looking.
I'll keep working the wheel back and forth
https://www.jamestowndistributors.com/u ... docId=1088
Here's a link on how to bleed from telestar, but i always just kept slowly turning lock to lock and adding fluid as needed. If you have to add a bunch of fluid, you need to look for a leak. I believe its most common at the hose connections behind your helm, but could be at the hose connection on your rudder cylinders, or bad o rings on the cylinder shafts.
Happy Steering!
- 650Guy
- Captain
- 650Guy
- Captain
Tomorrow AM I may just open up the panel under the helm to see if there is anything in there I need to see.
If there is no tank in there, I'm going to stand on a limb and say its NOT pressurized.
