Fuel transfer line
- vtcats
- Vessel Info: 2006 46 Voyager
Volvo D9-500’s - Location: Burlington VT
- Has thanked: 2 times
- Been thanked: 5 times
Fuel transfer line
My Carver 460 Voyager has a fuel transfer line between the two tanks that sit near the aft of the boat.
There is no pump transfer, it’s simply gravity/pressure I assume. I also assume it’s there because the genset draws fuel on,y from the starboard tank.
So my question is, if the boat naturally lists to one side (maybe not naturally, but due to weight distribution of tender, etc), and I open the transfer line, does the fuel simply move to the lower side of the boat regardless of amount of fuel in each tank, or does this even the tanks out?
Mallets Bay, VT
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Fuel transfer line
My take on it anyhow.....now if there was a pump then I believe you could level things off much like ballast tanks in large vessels.
- vtcats
Mallets Bay, VT
- Been thanked: 654 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Being that I also have two fuel tanks I will have to check to see if there is a fuel leveling line there too.
- vtcats
Second, I also have a gravity fed line between two 75 gallon water tanks on each side if the boat. I never thought to visually check them. I say, “visually”, because there is one sender that reads total for both tanks.
I pretty much live in my engine room. Can’t believe I never thought of that.
Mallets Bay, VT
RGrew176 wrote:Source of the post Being that I also have two fuel tanks I will have to check to see if there is a fuel leveling line there too.
You have a gas boat , so very unlikely.
- RGrew176
bud37 wrote:Source of the postRGrew176 wrote:Source of the post Being that I also have two fuel tanks I will have to check to see if there is a fuel leveling line there too.
So, it's something that only diesel boats would have. Just curious. Appreciate the information.
RGrew176 wrote:Source of the postbud37 wrote:Source of the postRGrew176 wrote:Source of the post Being that I also have two fuel tanks I will have to check to see if there is a fuel leveling line there too.
I believe so....rules regarding tank fittings are spoken to in the regs...Carver installed that line and isolation valves in his boat ( a diesel ) from the factory, according to the parts diagrams.
You don't want to find that type of system on your gas boat...IMO...
