Leak from transom shield
- Vincent3450
- Vessel Info: 1988 Carver Santego
Re: Leak from transom shield
- Vincent3450
After pulled out of water saw water leaking from transom shield. Will have transom shield and engine pulled and inspected. If major problem - like transom rotted probably throw in the towel. I hope can replace gasket to transom shield and go on.
The outer transom assembly seal rarely fails. What usually happens when it leaks there is the assembly gets loose from a bad transom. Before you go through the expense of removing the engine/s and transom assembly, try to tighten the nuts around the inner plate as I mentioned above. If you can tighten them more, you are compressing a bad transom. This will allow you to make a decision about the boat before spending big money for removing the engine. A good tech can also get a pretty good idea of the transom's condition by sounding it and taking moisture readings to help decide which way to proceed, or not. Until you get more information, I wouldn't be removing any engines yet.
