Fuel Filter Count and Location
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
Motors are 1995 Crusader 7.4 XLi's
Port side is where we're having the stumble, it's roughly around the same RPMs, but doesn't happen right away, or even consistently... Sometimes it doesn't do it all weekend. When it does act up it limits our speed to 9mph.
I did a tune up with plugs/cap/rotor/wires, but didn't drive it much more than an hour after that before the snow fell. I figured changing out the fuel filters would be smart to do also. I haven't done that since I bought the boat a couple years ago.
I located a fuel parts diagram, but it doesn't seem to line up with what I have. I should be seeing a donut shaped round fuel filter screen setup below the fuel water separator and I don't see one. I traced some lines, but they go from the fuel distribution panel to the filter and then to the pump. I will admit that I only spent about 5 minutes with my head upside down in the bilge, but based on the diagram I was expecting to see a donut looking filter down there somewhere obvious.
I was looking at a crusader manual, so it's possible when Carver added the distribution panel that it eliminated that filter.
Does anyone have any pictures of where the fuel filters are and how many per motor there are?
Still waiting on my trans rebuild, so I have some time to mess around with this.
- Been thanked: 654 times
Re: Fuel Filter Count and Location
Next in line is a water separator filter looks like this ....https://www.westmarine.com/buy/racor--1 ... or--108664 and last
There is a inline cannister filter at the tbi....https://www.go2marine.com/Fuel-Filter-R ... ader-23250
All are on stbd side of engine oberg down low,water seperstor mid height and cannister right next to tbi
- chpsk8
I'll go back this weekend and take some pictures if I can't figure it out. Thanks for confirming it might exist..
off to chase ghosts again....
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Viper wrote:Source of the post It may differ after minor modifications in their builds but check under the on board Racor filter on the same mounting bracket. It'll be a black puck with a nut & bolt in the middle.
I have the same water fuel separator. (110A) I can’t get the nut loose on the bottom. I have tried a pipe over the end of my wrench, but just can’t seem to get it off. I am concerned about snapping it off where it is attached to the engine. I was able to drain the water out of the bottom. Any thoughts on how to loosen?
- Helmsman
Viper wrote:Source of the post You can try penetrating oil or a product like Freeze-Off or PB B'laster. If it doesn't come out with that, do yourself a favour and replace the assembly. The last thing you want to do is bend the bracket or warp the housing and cause other issues like leaks or runability problems.
Ok. I will order two new ones.
- Helmsman
Nharrison5 wrote:Source of the postViper wrote:Source of the post You can try penetrating oil or a product like Freeze-Off or PB B'laster. If it doesn't come out with that, do yourself a favour and replace the assembly. The last thing you want to do is bend the bracket or warp the housing and cause other issues like leaks or runability problems.
Ok. I will order two new ones. Is the canister supposed to be just hand tightened? Again, it is a Racor 110a that I changed the filters on two years ago. Just curious, so that I don’t create a problem with the new ones.
- chpsk8
Got an email this morning that the donut had been removed and replaced with an inline filter by someone. They changed those inline filters so we're good now.
A. I'm not crazy and really didn't see it because it didn't exist.
B. Woohoo! Glad they found it and replaced it, that's the last bit of last falls tune up I wanted to get done.
Launching tomorrow, I'll follow up to report back on the trans whine that should be gone now.
