396 Stereo Lovers
650Guy
370 Cummins
Been thanked: 40 times
396 Stereo Lovers
Postby 650Guy » June 16th, 2020, 5:24 pm
Hello all 396 owners. I'm contemplating upgrading my stereo. Currently I have 2 independent radio's installed which is quite cumbersome.
what I would really love to do is remove both, and install a single unit that I could hear and use anywhere. To complicate things more I would REALLY REALLY love to tie in the TV so it could support the surround sound.
Has anyone tackled such a project? Maybe just upgraded the radio? I'm really not looking to putting a Dance Floor in my 396, just looking to get some idea's from what you all have done.
Would I be TOTALLY crazy to try and install a home surround sound system in? I mean if its in the main salon, its as comfortable as my family room of my house... :-D
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Re: 396 Stereo Lovers
Postby Tireless » June 16th, 2020, 10:03 pm
I have kept what was in the boat when I bought it and it works for me. I have a Fusion Stereo/DVD player beside the TV in the salon. It provides great sound through two ceiling speakers and a sub that is behind the curl of the sofa in the salon. It is wired to the TV for DVD’s.
I also have the Clarion Stereo on the dash in the fly bridge with a 1000 watt amp that pushes sound into the bridge with a sub, aft deck and the cockpit. I can play sound in the fly, aft deck and the cockpit or cancel the sound in these area’s using the fade. The speakers are JL Audio and they are very nice.
I have considered having one system, but I like to be able to separate the sound from inside the salon and outside. This is so the Admiral can do her thing and I can listen to what I want.
If I was going to upgrade I would just get a newer Clarion on the dash for bluetooth capability and better FM reception. I currently use a Bluetooth device hooked up through the Aux.
Greg
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Postby SplashyLady » June 17th, 2020, 10:34 am
Interesting! Yes, you could use a home-based A/V surround setup. I've seen this done! I assume your boat has a generator, but you will want the system to work when the genny is not running. What you will need is an inverter and maybe a separate dedicated battery to power the A/V system. The battery will be charged by the normal 12VDC charging system. Most home audio systems today don't need tons of current, as the amplifier circuits have become more efficient over time. Take some time to decide what you want (number of speakers, inputs, bluetooth, wireless, etc.) and find a system that meets your needs. Try to minimize the number of components for ease of use and maintenance. Also be careful with location, as home based components are not designed for wet location use. Once you get your ideas together, call someone knowledgeable and discuss equipment options - like how many channels the amp might need, switching, etc. I would suggest a discussion with the folks at Parts Express - they kind of specialize in unusual or professional solutions and their folks are very good.
https://www.parts-express.com
Good luck!
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
650Guy
370 Cummins
Postby 650Guy » June 17th, 2020, 4:00 pm
Oh man... that just dawned on me... DUH!!!! Underway the home system will not work... man, sometimes I miss the most obvious of things!
I do have a gen, and 99.9% of the time that I'm underway, I run it. the Denon AVR-S710W system I'm thinking of using has zone control, streaming ability and Spotify built right in. an APP that uses the WIFI system to control the unit, so AGAIN, if I have AC power my router is on, and can control it from anywhere on the boat. its a pretty sweet box! but no AC... its just dead weight on the boat! LOL
So plan B.
What if I leave the existing equipment installed, add the home system, simply splice into the speaker lines and in the event I do not have gen running, I could still use the standard system....
OR....
I could just be like a normal person and get a new radio that works on DC....
SplashyLady
Postby SplashyLady » June 18th, 2020, 11:42 am
650Guy wrote:Source of the post Oh man... that just dawned on me... DUH!!!! Underway the home system will not work... man, sometimes I miss the most obvious of things!
Don't discount the idea of the inverter - less than $100 for a 1000W inverter and you can run the system any time off the 12 VDC. You could put a small 12 V cube battery inline nearby as a reservoir (similar to using a capacitor, but less hassle) to stabilize the 12 VDC stereo power to the inverter. The Denon AVR-S710W is a 75W x 7 system with a maximum 400 watt input load. I doubt if you would ever run that system wide open for very long! Nominal load would likely be less than 100 watts.
KRIËGER 1100 Watt 12V Power Inverter Dual 110V AC Outlets, Installation Kit Included, Automotive Back Up Power Supply For Blenders, Vacuums, Power Tools MET Approved According to UL - $85 from Amazon.
Connecting speakers to two different sources often causes problems; amplifiers are not designed for back-feed and impedance could be a problem.
Captain John
Lake Norman, NC
Postby Midnightsun » June 18th, 2020, 12:40 pm
Piece of cake. Take a look at the Fusion line up. I have an older one but it still can do 3 zones. Single unit in the slot with a controller up on the fly. Controls volumes independently of zone or all together. They stream, do airplay, sirius, you name it. Really versatile and made for the marine environment.
I chose their blackbox unit as the main can be hidden anywhere, just a small remote that controls everything. Lots of options. https://www.fusionentertainment.com/marine
