New Owner
- Gag_Halfront
- Vessel Info: 1990 Carver Mariner 3297
- Been thanked: 20 times
New Owner
-- David
- Has thanked: 469 times
- Been thanked: 1765 times
Re: New Owner
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
Re: New Owner
2022 Stingray 182 SC
- Has thanked: 64 times
- Been thanked: 481 times
Re: New Owner
- Gag_Halfront
Re: New Owner
This particular example was a donation to a charity, then bought by someone who let it sit for several years and now, I bought it as the marina where it's stored wants it _OUT_ by the end of the month. It's a tall order, but small block chevy engines aren't really mysterious, all the through hulls look good, one bilge pump needs replaced, but from a "does it float? Does it run?" perspective I think I've about got it ready to launch,
My latest problem is that I just discovered today that the helm does squat. Apparently (as I've learned by reading the forums tonight) low hydraulic fluid is a thing you have to watch out for on these older boats, so that's ok. I can sort that out. What's troubling is that when I try to turn the rudders by hand (big channel lock pliers and some muscle) they turn to port just fine, but don't turn to starboard. I think I'm probably going to find that the hydraulic slave cylinder is toast. Troubleshooting this is my primary goal tomorrow.
I'm also trying to figure out why the starboard ignition switch doesn't seem to do anything. Could be the switch itself is fubar, could be bad wiring somewhere. I don't think it's the engine itself because I don't even get an alarm when I turn the ignition on. Nada. The previous owner is supposed to be sending me tons of manuals and documentation including schematics, but there's almost no chance it arrives before I have to have the boat out.
Anyway, nothing but fun, right? That's why we get into this hobby. Because we don't have enough problems.
Re: New Owner
Gag_Halfront wrote:Source of the post ......What's troubling is that when I try to turn the rudders by hand (big channel lock pliers and some muscle) they turn to port just fine, but don't turn to starboard....
That's not uncommon even in a properly working hydraulic system. I would focus more on ensuring the fluid is at the proper level and bled so there is no air in the system. Low fluid and air will prevent it from working properly.
As for the starboard no start, it could be a number of things but start with the simple stuff like ensuring the shifter is in neutral. To check if it's out of adjustment, turn the ignition switch to the start position and keep it there while to move the shifter back and forth between forward and reverse. If she turns over while moving the shifter, the neutral safety switch is out of adjustment.
I'm assuming you've checked and ensured your batteries are up to par?
What brand and model of engines are we talking about here?
- Gag_Halfront
Re: New Owner
The engines are mercruisers. 350 small blocks. I have not tried the shifter test. I will investigate that tomorrow. I did find a breaker of some kind just behind the distributor on each engine. On the port engine the "push to reset" button pushes properly and that's the engine that works. The button on the starboard engine's breaker did not push and there was no continuity across the terminals. As a temporary test I removed the breaker and connected the two ring terminals of the leads together. This had no effect. I'm not sure exactly what the breaker is for, but I do know that it's faulty. I also know it doesn't seem to be the cause of the problem.
The batteries are brand new. I replaced all of them very first thing.
If these were automotive engines, I would expect the large lug to the solenoid to be the positive battery cable and connecting a starter test button between that lug and the smaller lug would engage the starter. On the boat, I have no idea what path the circuit takes to get from the battery to the engine ignition and starter. Any further insight would be most appreciated.
Thank you so much for the advice. I'm looking forward to doing more with the boat than crawling around in the engine room.
Re: New Owner
Do you hear any clicking at all at the engine when you turn the key to the start position? There should be a slave solenoid at the front left side of the engine probably in the housing where the breaker is. If you take a listen at the engine while someone turns the key, you should hear it click. If it clicks but doesn't turn over, chances are the solenoid is faulty. If it doesn't click, there is a problem with the control circuit. Can you post an engine serial number?
- Gag_Halfront
Re: New Owner
Thanks again!
- pepmyster
8.1 Volvo Penta
- Has thanked: 487 times
- Been thanked: 206 times
Re: New Owner
