454 CI carburetor question
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 41 times
- Been thanked: 11 times
Re: 454 CI carburetor question
- VicB
- Been thanked: 1111 times
VicB wrote:Source of the post Good thoughts. They have new choke pull offs. They were included in the rebuild. One thing I did wonder was that my engine runs about 110 degrees and the cooling thermostat opens. They are raw water cooled. I wondered if the thermostat would get warm enough to work correctly. If there is an exhaust passage just below them, I’m sure it gets plenty of heat right there.
They may be new, but are they good and working properly?? Also, they do need to be adjusted so they pull the butterfly open the correct amount after the engine starts.
Users browsing this forum: Google Adsense [Bot] and 26 guests
