Not Going Into Forward Gear
vgcapano
Vessel Info: 1989 Carver Mariner 32
Twin 350 Mercruiser 5.7L Motors
2001 Seadoo Challenger 2000
1994 Sea Ray Sea Raider (sold)
Postby vgcapano » July 6th, 2020, 1:20 pm
Ladies and gents I’m having an issue with my starboard mercruiser 350 motor not going into forward gear. Long story short,I took my kids out and came back. While attempting to moore the boat, I found my starboard motor would stall out when put in reverse. I got the boat docked and went to look at the cables. I found that the shift cable came loose from the bracket it kicks down into. I put it back on and tried the boat gears. I now have the opposite issue of having reverse but no forward gear. I have tried adjusting the cables as anyone would but I have had negative results. I was recently in the eng compartment manually shifting the lever on the drive (shift cable not attached) moving from reverse to neutral just fine but forward gear will still not engage. Any thoughts as to what it could be? Please advise when you have a moment.
Re: Not Going Into Forward Gear
Postby km1125 » July 6th, 2020, 5:21 pm
Does the shift level 'click' into the fwd position but the drive does not engage?
Have you checked the fluid level? Are these velvet drives or some other transmission?
vgcapano
Postby vgcapano » July 7th, 2020, 1:15 pm
As far as the drives, I believe they are bravo v drives. The transmission fluid container level is still good. The only click sound I hear when manually shifting the lever attached to the arm is when moving out of neutral. Forward gear just does not want to engage.
vgcapano
Postby vgcapano » July 7th, 2020, 1:16 pm
The drives may be apha as well. I am not sure how to tell the difference between them to be honest.
Postby Viper » July 7th, 2020, 8:46 pm
So can you clarify that this is definitely a sterndrive application and not an inboard application (shafts, rudders, etc.). The terms being used are getting a little confusing.
Postby tomschauer » July 8th, 2020, 9:40 am
If you have alpha gen I outdrives, which is most likely what you have for 1989 350's there is a special procedure to set the shift arm. You should be able to look it up on youtube fairly easily. Also, it will not just go from f-n-r without some prop spin to engage the gears.
vgcapano
Postby vgcapano » July 8th, 2020, 1:39 pm
I definitely do not have a stern drive. It’s a V Drive. I wasn’t sure if it was an alpha or bravo though. Tomschauer, I will look up the procedure online. Thanks for clarifying what drive I have. Is it easy for the shift arm to get out of alignment and need adjusting?
Postby tomschauer » July 8th, 2020, 3:23 pm
OK, if its a V drive then you do no have a bravo or alpha stern drive.
Better look up some pics, and make sure what you are working with.
Postby Viper » July 8th, 2020, 10:06 pm
That's why I'm asking for clarification, v-drive and alpha/bravo being tossed about for the same application. A v-drive is a transmission used in an inboard application that will be hooked up to a shaft going through the hull, a shaft strut and a rudder, all under the hull. An Alpha and a Bravo are models of sterndrives (external transmissions) that hang off the back of the transom, no v-drive needed.
Sterndrives:
https://www.google.com/search?q=sterndrives&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiHsJqUiL_qAhVQK80KHR48AH4Q_AUoAXoECBAQAw&biw=1229&bih=608
Inboard:
https://www.google.com/search?q=inboard+v-drive+boats&tbm=isch&ved=2ahUKEwi9y4ftiL_qAhVGja0KHVo3BnQQ2-cCegQIABAA&oq=inboard+v-drive+boats&gs_lcp=CgNpbWcQAzIICAAQCBAHEB46BggAEAcQHlDse1inmQFg6p0BaABwAHgAgAH1CIgB2CSSAQszLTIuMS4xLjIuMZgBAKABAaoBC2d3cy13aXotaW1n&sclient=img&ei=pHkGX73pLMaatgXa7pigBw&bih=608&biw=1229
vgcapano
Postby vgcapano » July 11th, 2020, 11:08 am
I appreciate your responses. I was under the impression that the v drives had an A or B attached to them. Thanks for clarifying. Still no luck with getting it in forward gear.
