new Carver owners with a minor pre trip issue
- dennis gasper
- Vessel Info: 2003 466
Thanks Dennis
- mjk1040
- Been thanked: 248 times
Re: new Carver owners with a minor pre trip issue
- dennis gasper
Try disconnecting the float switch wires, at this point it should stop running. Connect the 2 wires together and it should start up. If this test works then the float is defective.
- dennis gasper
- dennis gasper
When I disconnect the float switch wires the pump continues to run. The only way to shut it off is at the breaker. I also connected a new Rule 3700 just because And same thing. My only option I guess is to change out all wire connections starting with the ground even though they look solid.
- Has thanked: 602 times
- Been thanked: 1310 times
- dennis gasper
- dennis gasper
thanks again for your responses everyoneReturn to “Introduce Yourself!”
Users browsing this forum: No registered users and 53 guests
