325 Aft Cabin Outlet Diagram
- Thekaj
- Vessel Info: 1995 325 Aft Cabin
- Been thanked: 4 times
I’m assuming this is an issue of either a dead outlet or bad connection somewhere in the line. I pulled several outlets and ran a voltage test, but couldn’t find the culprit (none are receiving juice). I figure if someone knows the order the outlets are wired, I can focus in on the first dead one.
Thanks in advance!
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
Re: 325 Aft Cabin Outlet Diagram
Any chance you have a tripped breaker you haven't noticed?
- Been thanked: 646 times
- Thekaj
And I definitely have been checking through the AC panel for any issues. There are three that connect to outlets, and all three have live outlets when on. Plus, I confirmed voltage on all of them.
Thanks for the tips!
- Been thanked: 601 times
Sometimes they are under counters, or in cabinets, but hey are there somewhere.
- Has thanked: 598 times
- Been thanked: 1281 times
Thekaj wrote:Source of the post I did find another GFCI outlet on the bridge. I confirmed it’s at the end of the circuit, but I plan on replacing it anyway.
Make sure while you are checking that you have unplugged all appliances etc from those circuits you are checking.......if one has a fault it will keep the circuit off.
I think I counted somewhere around 7 on the schematic and parts list G36 put up.
