Bilge Pumps Refit - High Water Alarms
- vineyardgray
- Captain
- Has thanked: 128 times
- Been thanked: 33 times
- Contact:
However, this experience did not particularly sit well with me; had I not opened the engine baycover on a whim, the engines could have well been underwater without warning.
Then this season I found the engine bay float switch blocked with a hose and then found the miships pump NFG, I decided that something needed to be done.
The system that I am working on now will:
- have all new parts
- use electronically operated switches to detect water (no jamming, no failure due to moving parts)
- monitor pump cycles for each pump (I want to know if pump cycles are status quo or getting more frequent, signalling an issue)
- allow for auto/manual/off operation
- sound an alarm for high water condition (pump runs for more than N minutes)
- allow future tie-in to NMEA or SignalK onboard networks
- are correctly fused/breakered
Stay tuned...
1988 Carver
3867 Santego
PCYC
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: Bilge Pumps Refit - High Water Alarms
“Escape Plan”
Murray, KY
The electronic bilge switches are not that reliable. A high water alarm switch is really never in the water therefor nothing to foul it over time so a conventional float switch will be your best bet IMHO. . Purchased a standard float switch and wired it to a combo led/buzzer which was located at my dash. Just install the float switch about 2-3" higher than your existing float switch is installed, connect the float to ground and to light/buzzer and the second terminal of the light/buzzer to 12v positive.
I installed one on my previous boat which was a DIY. Combo led/buzzer https://www.ebay.com/itm/Panel-Mount-22 ... Swx2VZiJz6.
Part 2. I personally have boat command on board. This unit can be connected to the float switch to monitor high water alarms via text or email, best of all only $80 a year however you do need internet on board. https://boatcommand.com
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
- vineyardgray
- Captain
- Contact:
As usually happens when I've created a plan, something else breaks and requires attention. My shower sump quit and I had to scramble to get a new pump ordered.
Turns out the sump uses a pump cartridge unit made by Johnson Pumps/SPX.
This is a pretty neat little pump system - no messing around with trying to get the hoses off of the old pump to replace it, easy to pop out the pump and clean the impeller if needs be. Plus it takes a lot less space to carry one of these parties on board as a spare than a whole rule pump.
I think I'll use these pumps for the retrofit of my bilge system. Next the switches.
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
I'm going to use three of the BG-SWA, which is a switch with integrated high water alarm. I will also be using three of their advanced bilge control panels, which contain alarm, fuse, on/off/auto, and a screen that cycles through: pump count, voltage, current draw and run time.
The panels will be mounted close to the original breaker location for the bilges (under the companionway step) this will simplify wiring as all the wiring already runs to that location for power.
My boat has no lower helm (fly bridge only) so having the on/off/auto switches up there makes little sense although I would like the high water alarm to sound up there but I haven't figured that out yet.
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
1988 Carver
3867 Santego
PCYC
