Tireless wrote:Source of the postdarrenlife wrote:Source of the post I’m just getting myself familiar with this technology so forgive my questions if not applicable but noticed you are hoping to get 35A through a 30A controller, is this possible? Won’t the controller limit charging output/capacity to 30A?
Good luck with the installation! Chris was very helpful and was very patient to answer all of my questions.
I have he same charge controller and love the Bluetooth capability and not having to wire a separate remote, lots of data and trending available.
It was a clear, sunny day during my install and it reached about 298W input and around 22A output which seemed reasonable. I’m hoping this will give me enough to balance the draw of 18 year old fridge which runs constantly ( next project)
I haven’t measure the input current at the batteries yet but will post when I do
Good point, still trying to get my head around all of the techno stuff myself. I was told that is what the panels will produce, but I expect that the 30 Amp controller will maintain at the appropriate level. It is the Victron SmartSolar 100/30 MPPT Solar charge controller. The panels are 4 X 110W Sunpower E-Flex.
I was advised to put a 30 amp breaker between the panels, on the positive lead and the controller and they supply a 40 amp fuse to install before the battery. I am also going to put in an on/off switch beside the battery.
I am installing the controller in a cabinet in my aft deck, which is about 15' from the panels and then I am going to run 8 gauge wire to the switch, fuse and battery. I don't think I will loose anything. Chris is coming to my boat this evening to deliver the equipment and I will be going over the install with him as well. Fingers crossed.
If the set up does not give me what I am hoping for, then I will add two more panels and a second controller.
Greg
Solar panels
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
Re: Solar panels
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Solar panels
darrenlife
Re: Solar panels
I’m sitting at the bottom of the Bobcaygeon lock in 40mph winds and magnets are holding strong
- pepmyster
8.1 Volvo Penta
Re: Solar panels
darrenlife
Re: Solar panels
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Solar panels
I was able to fasten the panels to the flybridge hardtop with 1" elevator bolts, secured with 3M 4200. Solid as a rock.
Going to install a small pure sine wave inverter this weekend near my stateroom for my CPAP machine. Getting old sucks. I am tired of using the alligator clips on the battery and an extension cord every time I went to bed.
Wish they would hurry up with the wireless panels, lol.
I will put it to the test at the end of the month during our trip to the North Channel, but so far seems to be working great.
Greg
- Tireless
Re: Solar panels
Bottom line, solar was a great investment for us and I was never concerned about running out of juice while on the hook.
Greg
Re: Solar panels
- Been thanked: 654 times
Re: Solar panels
darrenlife wrote:Source of the post I just installed (3) Sunpower panels that I purchased at Toronto Boat show. It was a package with a Victron MPPT 30A controller. I used magnets to attach to the canvas.
do you mind posting what magnets your using?
- Tireless
Re: Solar panels
Midnightsun wrote:Source of the post Only recommendation I can give is to insert a spacer so as to lift the panel slightly off the roof, they Are more efficient if they "breath" as in not getting too hot.
Sound advice Midnightsun. The bolts themselves have a space from the base up, about 1/2". I also placed a washer under the panel on top of the elevated part of the bolt. Mine are elevated around the perimeter for sure, however may be touching in the middle. My plan is to put a piece of corrugated plastic sheet in the centre of each board at the end of the season to lift it up.
Thanks for the tip.
Greg
