Quick Windlass Genius 1000 800W 12V
- Peter3607
- Vessel Info: 1998 Carver 500 CMY
1989 Carver 3607 Aft Cabin - Location: Ontario
- Has thanked: 29 times
- Been thanked: 2 times
I should mention this particular windlass comes complete one unit that sits on the deck. No motor mounted below deck.
Re: Quick Windlass Genius 1000 800W 12V
- Peter3607
tomschauer wrote:Source of the post Did you verify you have 12vdc at the motor. If it was stuck in the up position you may have popped the breaker.
I believe there was power to the motor according to the electrician that diagnosed.
- Peter3607
That said, if it was a popped breaker, where would I locate such breaker to verify its pop-worthiness?
- Been thanked: 1111 times
Peter3607 wrote:Source of the posttomschauer wrote:Source of the post Did you verify you have 12vdc at the motor. If it was stuck in the up position you may have popped the breaker.
Hard to say, exactly. On the 3607 there is a "windlass" breaker position in the middle of the main DC panel, but it may not have been used. If you do have one there, check to see if there are large wires on the back. If they did use it, it may have just been for the control circuitry and will only have relatively small wires (12ga or less).
The other thing you can do is try to trace the large wires from the windlass back to the batteries. Just look in the forward engine room bilge for any pair of large wires going forward and that's likely them. You can trace from there back to the batteries to see where they connect. Technically, there should be a breaker or fuse 6-7" from the battery, but that requirement is not always complied with.
