House Battery Charging Issue
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
I have discovered that my house battery is not charging while underway. I checked and the alternators are working. The starting batteries are charging but for some reason the charge is not making its way to the house. The house battery does in fact charge when plugged in dockside electric. All wires seem tight.
One question is how is the battery wired so that only the house battery will discharge for d/c demand while the starting batteries do not discharge, yet is able to accept alternator charging.
I there some solenoid or switch that can be defective?
Any thoughts and insight are much appreciated. Thanks.
- Been thanked: 654 times
Re: House Battery Charging Issue
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
- Has thanked: 602 times
- Been thanked: 1310 times
The tell would be to disconnect your shore power, gen off then try DC house loads, put multimeter on the house battery then start an engine and see what registers, or disconnect the leads on the house battery and have it load tested.
Also like g36 states, ya never know what has happened before you..plus consider what darrenlife says...good luck with it...
- denpooch
I let the battery 'run down' yesterday and put a meter on the battery and started the engines. No movement. I do know the alternators are working from dash voltmeters. The battery is brand new this season and has been tested.
I am gonna check all circuit breakers and look for an isolator.
Thanks folks, I will keep you posted on progress.
- denpooch
The battery has 3 red cables connected to positive terminal of the house battery. The largest seems to feed the system. Second seems to be the input from onboard charger. The last is inbound from the isolator. This cable went from the terminal to a breaker and that breaker needed to be reset.
I checked voltage before and after starting the engine. She is charging!
Thanks for your advice.
