Starting problem on my 2001 Carver 404
- Dave123
- Vessel Info: 2001 404 Cockpit Motor Yacht
- Has thanked: 5 times
- Been thanked: 3 times
The boat has 4 6-Volt "house" batteries. It also has 2 starter batteries fir the engine (and another battery for the generator). When I switch the battery selector to #2, the boat starts fine. However, when I switch the battery selector to #1, I hear "clicking" but the engine will not start.
I replaced all house and the #1 batteries. This did not help. Also, when running on battery power (not shore power), lights dim and equipment flickers on/off. Obviously, in replacing all the batteries, I examined & changed all battery connections.
I suspect that, in the 20 years that the boat has been around, someone may have changed the wiring. I have searched for a wiring diagram without success. After replacing the batteries, I don't know the next step.
Any help would be really appreciated.
Re: Starting problem on my 2001 Carver 404
- Has thanked: 602 times
- Been thanked: 1310 times
On your switch panel are a number of breakers to route 12v power, and behind that panel the wiring and cables are packed in there real tight....I know with our old boat upon checking back there found connectors loose and some cracked from the bends and tension, in fact it actually cracked/broke one of the breakers.
Just try to do one thing at a time and you will get thru it.
- Dave123
- Dave123
So, battery #1 did not have a strong ground to the engine. That was the cause of the engine note starting. Obviously, there was some ground because I heard the ticking when I turned the key.
So, I purchased and installed a ground from battery #1 to the engine. Now both batteries start the engine. Also, the electrical equipment works better including brighter lights and no flickering. But, I will have to wait until next season to make sure.
2 important questions:
1) Any guess why there was no cable from battery #1 to the engine? Why were the two grounds somewhat isolated from each other?
2) The battery monitor alarm sounds for the first hour while charging the batteries. The monitor is reading a "high voltage." This voltage drops after the batteries receive a full charge. Then, the alarm stops. Is this normal?
Proper grounding in a boat is extremely important for operation and safety, it is good you are working your way thru this, thanks for posting.....
- Dave123
I have 7 batteries including four 6V house batteries (two in series; two in parallel). I also have two ProNautic 1250 battery chargers and a "BMV-6025" battery monitor alarm. If this "upgrade" was added, I should be happy. However, it doesn't seem like it was done correctly. Or, a grounding line was removed for a reason that isn't clear.
To answer your question... I do not know if there is a grounding cable between the blocks. Where should I look for it?
Regardless, an incomplete ground existed between the "engine" and "house" grounds. "House" grounds are connected between several grounding plates around the boat and battery #1. I added a grounding line between battery #1 and the engine. The lights are brighter and engine starts from battery #1. Therefore, the "house" was incompletely grounded to the engine block. I just want to know that I did the correct thing. Forgetting a ground between the battery and the engine seems rather dumb for someone who made all these upgrades.
One last electrical question... when I switch on the battery charger, the charger initially reads 15V and ~50amps. The "BMV-6025" battery monitor alarm rings because the voltage is above 13.8 Over about 1 hour, this gradually falls to ~13.5V and 20amps. The battery monitor then stops alarming. Should I be concerned?
- Been thanked: 1111 times
Some chargers have a "equalize" mode which is a temporary higher voltage. The old Heart Interface inverter/chargers had this and there was a switch to enable it. If that switch was on, then the charger would enter this mode every time it was powered up. You would typically only toggle that switch once to engage that mode every month or so, as you don't want to go into this mode every single time you power cycle the charger. See if your charger has any documentation about "equalizing" the batteries.
... and YES, you should be very happy with those upgrades. That's a good house battery bank and having that monitor is also great. Even if the PO missed some things in the installation, they are very minor in terms of what they added to the boat.
Dave123 wrote:Source of the post
Dave123 wrote:Source of the post One last electrical question... when I switch on the battery charger, the charger initially reads 15V and ~50amps. The "BMV-6025" battery monitor alarm rings because the voltage is above 13.8 Over about 1 hour, this gradually falls to ~13.5V and 20amps. The battery monitor then stops alarming. Should I be concerned?
I will add to KM's info.......If you have the BMV 6025 manual you need to read the set up instructions....this monitor needs the correct info or it will not work properly.......you should see voltage well over 13.8 until the batteries catch up....the info will be in the 1250p manual about charging profiles.....the chargers also need to be set up properly. The 13.5 volts at 20amps seems a bit off to me.
The thing in your post that throws me a bit is your explanation of the 4x6volt batteries as 2 being in series and 2 being in parallel...the install should be series/ parallel meaning voltage read across the bank main pos and neg should be 12 volts...actually 12.7 full charged after sitting. The two batteries on one side are in series and the other two are in series making each separate set 12.7 volts ...then the two sets are joined in parallel. You can get example schematics online.... Please check your set up.
My quick guess judging by the install..... these items may not have the correct set up info put in on instal start-up. I am thinking this will take a while to go thru.....tough to realize exactly how the instal is in a forum setting but its a start....
Oh, your info from Carver is just how these boats came stock.....mine was just the same.
