1982 3607 aft cabin
- Vagabond302
- Vessel Info: 3607 aft cabin, 1982
1982 3607 aft cabin
It is just labeled ON/OFF, It does not seem to do anything.
On shore power it does nothing.
On GenSeyt power it does nothinh.
I am thinking it is supposed to and it is defective,
Any help would be appreciated.
Thanks,
Ned
- Has thanked: 598 times
- Been thanked: 1281 times
Re: 1982 3607 aft cabin
Sorry kind of simplistic but that is all I got till someone with the same boat chimes in.
- Has thanked: 78 times
- Been thanked: 1093 times
There are three separate panels there. The top would be for D.C. and the bottom two would normally for for two A.C. inputs. The middle one is for most of the 'normal' A.C. stuff and the bottom one would be for HVAC stuff. My bottom panel was blank because my boat did not come from the factory with HVAC.
Is this switch in the bottom of the D.C. section or the very bottom of the panel here the HVAC would be?
Definitely check behind as bud says and see where the wiring goes and what type it is. That will be some clues. It may be fed from a particular circuit breaker that might also give you a clue (like a windlass breaker).
- denders
- Vessel Info: 1985 Carver 3607 Aft Cabin
- Has thanked: 2 times
- Been thanked: 24 times
- denders
- denders
- Vagabond302
