Solar panels
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Solar panels
Thank you again!
- Been thanked: 654 times
Re: Solar panels
- tonyiiiafl
Re: Solar panels
Re: Solar panels
- tonyiiiafl
Re: Solar panels
Re: Solar panels
Re: Solar panels
- tonyiiiafl
Re: Solar panels
- tonyiiiafl
Re: Solar panels
I have already switched all lighting to LED, made a huge difference. Also!tonyiiiafl wrote:Source of the post Totally appreciate the share! I am thinking of expanding the bank to 4 T105’s. Silly thought but with the single 12V starting and the single 12V genset battery, I would assume the charger ProMariner 50A 3 bank charger. So I would assume that the other two GC batteries will be set up in parallel to the original 2, making a big 12V bank. Charger will know what to do as far as charging the bank. Yes, I am also going to look into the solar to help keep the bank charged during the day. today for example, I went from 9:30AM until 5:00PM using the house bank. When I switched on the genset to charge the bank, it was still at 90%.
- tonyiiiafl
Re: Solar panels
I have a 2500w/5000 surge inverter already installed, so I can run an extension cord to the inverter for TV.tonyiiiafl wrote:Source of the postI have already switched all lighting to LED, made a huge difference. Also!tonyiiiafl wrote:Source of the post Totally appreciate the share! I am thinking of expanding the bank to 4 T105’s. Silly thought but with the single 12V starting and the single 12V genset battery, I would assume the charger ProMariner 50A 3 bank charger. So I would assume that the other two GC batteries will be set up in parallel to the original 2, making a big 12V bank. Charger will know what to do as far as charging the bank. Yes, I am also going to look into the solar to help keep the bank charged during the day. today for example, I went from 9:30AM until 5:00PM using the house bank. When I switched on the genset to charge the bank, it was still at 90%.
