Throttle cables - clean and oil or replace?
Topic author Great Britain
PossiblyPaul
Vessel Info: Hornbill III
1988 Carver 2827 Voyager,Volvo Penta TAMD31 engines.
Ardglass Marina, County Down
Has thanked: 48 times
Been thanked: 6 times
Postby PossiblyPaul » September 5th, 2020, 4:51 pm
This subject may have been dealt with previously, but my 'searching' skills are poor, so forgive me if it's a repeat. I posted it in the wrong forum so apologies again.
My throttle cables are very difficult, and one is not responding well at all; advice from the sages at my marina is to replace them, but I tend to think that they have not been maintained during the past few years, and a search on t'Internet popped these devices up:
Thefirst one is labelled a 'Hydraulic Cable Oiler', and appears to be a more heavy-duty item than the others.
Are these of any use on a boat such as a Carver 2827, for the various control cables? They seem to be made more for the motorcycle user, whose cables are very much shorter than those from my bridge down to the engines. I don't want to remove the cables either, other than to release from the control points - is that feasible? Grateful for any advice.
Funga Safari
Has thanked: 474 times
Re: Throttle cables - clean and oil or replace?
Postby Viper » September 5th, 2020, 10:41 pm
Do yourself a favour and replace the 30+ year old cables. You'll be glad you did. If you can get them across the pond, the Sierra Extreme cables are a good brand.
PossiblyPaul
Postby PossiblyPaul » September 6th, 2020, 5:41 am
You may be wholly right in that, but... cash. Always explore the cheaper solutions first, they might just work - it could be that the cables are just mucky, and a squirt through of WD40 then oil is a credible solution.
Of course, when they don't you've spent more cash unnecessarily. But you've learned, which is Important. :)
Funga Safari
Postby bud37 » September 6th, 2020, 7:48 am
Have you considered a piece of clear hose over the end clamped to the disconnected cable then fill with the lube of your choice, clamp schrader ( tire ) valve in open end then pump some pressure in with bike pump etc and leave alone to let the fluid work thru the cable to the other end ?
You can google that , there are many versions of how, but basically simple.
PossiblyPaul
Postby PossiblyPaul » September 6th, 2020, 12:11 pm
Thanks, bud. That'll be my first attempt at righting the situation. Simple, probably quick and easy.
Funga Safari
Postby tomschauer » September 9th, 2020, 2:28 pm
If they are difficult to operate, odds are you have worn through the inner sleeve somewhere or at mulitple places.
Some lubricant will provide very short term relief at best.
PossiblyPaul
Postby PossiblyPaul » September 9th, 2020, 7:05 pm
Yes; coming out into the boatyard in about four weeks, so I'll have plenty of time over the winter to investigate. Meanwhile, I'm going to squirt some of 'A9 Racing Oils' PTFE cable lube down the lines and see what difference it makes (I've got that thing at Photo 2 above now, and might ruin the carpets, but hey).
Funga Safari
Superg
Vessel Info: 1985 Carver 3207 Aft Cabin
Harbored in Lake St. Clair, MI
Has thanked: 4 times
Been thanked: 20 times
Postby Superg » April 29th, 2021, 12:57 am
Hello PossiblyPaul,
I'm curious to hear if you were able to successfully restore the shifter cables to normal function. I have the same issue on my 1985. I'm also a fan of repair/restore before replace. Doesn't hurt anything as worse case scenario is you replace them anyway.
John T.
New Boat Owner (so lots to learn)
Harbored in St Clair Shores, MI
PossiblyPaul
Postby PossiblyPaul » May 2nd, 2021, 4:29 pm
Locked down for most of the time which should have been spent sorting out cables (and of course, all the other issues).
So, no. However, Son has the kit for doing a forced injection into the cables, and will hopefully be exercising his skills on that in the next week. All that lost time is really annoying, but I suppose it's a minor irritant in view of the Big Issues.
I'll post when we've done the business.
Funga Safari
Users browsing this forum: No registered users and 46 guests
