Cummins all of a sudden wont hit rated RPM
- zoomiej
- Vessel Info: 2001 Carver 466 MY
- Been thanked: 3 times
Is there anything from a turbo charge or fuel I should be looking for? Two engines, would one working at 100% pull the other up to rated RPM?
Looking for trouble shooting ideas please
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Cummins all of a sudden wont hit rated RPM
- zoomiej
Bowls are clean but I should change the filters. No smoke whatsoever, but will take a look at the air intake side as well. Thanks for the note.
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
My 356 will hit 35 mph with a clean bottom. 6-7 weeks ago, my top speed had dropped to 20 mph.
Had a diver come by and after he did his job, I got up to 32 mph.
I'm going to haul the boat for the winter and fully expect to hit 35 when I splash next spring with a clean bottom and fresh coat of bottom paint including Pettit Zinc Coat paint on my running gear.
- Has thanked: 598 times
- Been thanked: 1281 times
I can say, if I had a marine diesel powered boat, the first thing , I would join Boatdiesel forums.
- zoomiej
PJHoffnet
- Has thanked: 55 times
- Been thanked: 18 times
You might find the Seaboard Marine Cummins forums a great place to find answers to your engine questions.
https://www.sbmar.com/community/
- Zoomie
- Vessel Info: 2001 466
Thanks for all of the responses.
Cheers
- Zoomie
Cheers
rmidgett
- Vessel Info: Not yet acquired
- Has thanked: 2 times
bud37 wrote:Source of the post From my limited knowledge of marine diesels, it may just be that one engine is creating the problem, there by holding the other back.......now that said, you did say this was an all of a sudden occurrence.....so consider anything just recently done on board.
Users browsing this forum: No registered users and 6 guests
