1997 355 Aft Cabin aux tank
- True-North
- Vessel Info: 1997 Carver 355 Aft Cabin, lower helm station, Crusader 454 XLi engines, owner since 2007.
- Has thanked: 12 times
- Been thanked: 4 times
Re: 1997 355 Aft Cabin aux tank
If you never used it since you owned it, a previous owner may have tried some crazy sealant, or put something in there to prevent the tank from being used or to absorb the fuel smell.
- mjk1040
- Been thanked: 248 times
- True-North
True-North wrote:Source of the post Non ethanol has been used in this tank to my knowledge. Certainly not in the last 13 years we’ve owned it. The tank does not leak or emit a fuel smell. It seems fully in tact. As previously stated, I have run about 6 tanks (720 gallons) of fuel through it in the past few years with no issues other than the clogged fuel filters.
That certainly is a fair amount of fuel you have put thru there, clearly you would think that after that, all would be well.....but something happened here and what you are seeing seems like tank residue getting cleaned up.
Quite honestly, if it were mine I would decommission that tank again and let it lie.
- True-North
- mjk1040
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
buster53 wrote:Source of the post When it's comes to the aft aux tank, either completely empty it or use it on a regular basis. What I do, if I take a trip, that will use, say 100 gallons, I run both engines off the aux tank to get there and use the saddle tanks to get home. Doing it this way, I quickly use up gas in the aft tank which lightens the weight in the butt end of the boat.
I think that's a great policy for using a single aux tank like that.
It would be great if there was a second "fuel transfer" pickup that went all the way to the bottom of the tank so you could pump out the remaining fuel to one of the other tanks (though a filter) to completely empty it.
