1994 390CPMY faucets
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » September 20th, 2020, 11:52 am
I have a set of these original faucets in the galley that are old and in need of a replacement. Has or does anyone know of a direct replacement for these? Mainly concerned about the piping size that is in place versus what is there now.
Thanks!
Been thanked: 1180 times
Re: 1994 390CPMY faucets
Postby Midnightsun » September 20th, 2020, 12:05 pm
In all the boats I have owned, this is one of the first things I do, replace those cheap outdated faucets most boat builders use. I have never had any issues just replacing with regular household faucets both at the galley and heads which by the way are so much better in terms of quality and choice. The standard speedways always just fit like at home. Take a look at what you have and maybe bring it with you to home depot if you are not sure.
Been thanked: 646 times
Postby g36 » September 21st, 2020, 9:52 am
what.... you dont like what was made in 1994? :-P yep household stuff works well or you can spend some boat bucks and by marine specific
Been thanked: 601 times
Postby tomschauer » September 22nd, 2020, 10:29 pm
Yep, buy a good Kohler or Moen single hole single handle faucet the connections should be the same, but you will have a much better unit.
