Carver 406 AC /DC distribution panel removal
aloysius
Vessel Info: 2000 Carver 406
Has thanked: 16 times
Been thanked: 3 times
Postby aloysius » September 25th, 2020, 7:32 pm
How do you get to the back of the AC / DC distribution panel that's located in the wall just aft of the dinette?
Re: Carver 406 AC /DC distribution panel removal
Postby g36 » September 25th, 2020, 9:16 pm
Its very easy and its kind of hinged on the bottom not really a true hinge but if you'll Remove all screws around the panel except the 4 in the bottom middle. The ones on the outside bottom corners have to come out. Then it will tilt out from the top.
aloysius
Postby aloysius » September 26th, 2020, 2:45 pm
Wow. Thank you very much. Now I'm looking forward to trying it. My plan is to put a small light in the cabinet and also set up a 12v receptacle near the panel to access power to run / test various equipment used on the boat. Thanks again!
Postby g36 » September 27th, 2020, 12:24 pm
You bet. Both the light and 12v power access will be handy
Been thanked: 248 times
Postby mjk1040 » September 27th, 2020, 12:34 pm
Pictures of the project would be great!
Return to “Electrical”
Users browsing this forum: Google [Bot] and 31 guests
