Bilge Heaters
- Mike11
- Vessel Info: 1997 Carver 350 Mariner
- Has thanked: 4 times
Bilge Heaters
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Re: Bilge Heaters
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Re: Bilge Heaters
- Been thanked: 1111 times
Re: Bilge Heaters
Viper wrote:Source of the post What part of the bilge is this going in? If it's the engine compartment and you have gasoline engines, you need to ensure the unit is rated for a gasoline engine compartment. If it is indeed a gasoline application you have, 120 volt outlets aren't allowed in the engine bay.
Does that only apply to bilge heaters? Seems counter-productive to prefer a lower voltage, as the current would be correspondingly higher.
- Been thanked: 654 times
Re: Bilge Heaters
https://theboatsafe.com/
Re: Bilge Heaters
km1125 wrote:Source of the postDoes that only apply to bilge heaters? Seems counter-productive to prefer a lower voltage, as the current would be correspondingly higher.Viper wrote:Source of the post What part of the bilge is this going in? If it's the engine compartment and you have gasoline engines, you need to ensure the unit is rated for a gasoline engine compartment. If it is indeed a gasoline application you have, 120 volt outlets aren't allowed in the engine bay.
If you're referring to the outlet, voltage doesn't matter, everything just has to be hardwired, no outlets allowed. The most common things I see plugged in are chargers, heaters, and inverters
Big no no.
G, what are you using for remote temp monitoring? Was thinking of doing the same just for curiosity.
Re: Bilge Heaters
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Bilge Heaters
Mike11 wrote:Source of the post Hello everyone. I need to purchase a bilge heater for a 1997 350 Mariner. Does anyone suggest a particular brand and size? I have been told the "XTREME" heaters are the best but wanted to see opinions of this group. Also, does the bilge have an outlet or receptacle down in it? Haven't seen one yet but not sure. Thanks for any advise on this topic.
OK, I see you are in Georgia. Do you really need a bilge heater there? If you are keeping your boat in the water over the winter, chances are slim you will ever have a problem. Out of the water, possibly, but not in the water. You would have to have a couple days of hard freeze before you have any freezing damage as the water the boat is sitting in insulates the boat. A little skim ice on the water doesn't count. Now if you had 1" or more of ice, I'd be concerned.
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Re: Bilge Heaters
Viper wrote:Source of the postkm1125 wrote:Source of the postDoes that only apply to bilge heaters? Seems counter-productive to prefer a lower voltage, as the current would be correspondingly higher.Viper wrote:Source of the post What part of the bilge is this going in? If it's the engine compartment and you have gasoline engines, you need to ensure the unit is rated for a gasoline engine compartment. If it is indeed a gasoline application you have, 120 volt outlets aren't allowed in the engine bay.
Big no no.
- Helmsman
Re: Bilge Heaters
I live just north of you. I winterize the fresh water system. You have to watch your cockpit water connection. I usually drain that, then winterize. Also, a bilge heater may not provide enough heat all the way aft to the stern so AC systems, generator, etc. need to be considered.
