Bow Thruster Started up on its own!
Cricket
Vessel Info: 2003 Carver 530 Voyager Pilothouse
Has thanked: 2 times
Been thanked: 2 times
Postby Cricket » October 2nd, 2020, 9:09 pm
Hi Folks,
I have a 2003 530 Voyager. I live on the boat on and off. A couple weeks ago I was awoken in the middle of the night to the bow thruster running. It is a Volvo Penta BP1200 (24v). I rushed to the helm and tried reversing direction and deactivating the station. I also went to the upper helm and repeated this. No effect! I continued to fiddle and it would stop for a second when I reversed direction, then start up on its own again. After a couple minutes it stopped on its own and did not repeat this through the rest of the night. Later, I flipped the master switch in the engine room to be sure there was no repeat performance. This could have been a disaster if I hadn't been on the boat.
Question: what might have caused this malfunction? This could have been really serious if it had happened while docking. The relay? The joystick (rocker)? A loose wire? LoL. Any thoughts would be appreciated.
Tim
Re: Bow Thruster Started up on its own!
Postby Midnightsun » October 3rd, 2020, 7:15 am
Thruster starting up on its own at dock in total calm while you were sleeping is really going to be a mystery. Do you have a remote control for the thrusters?
Cricket
Postby Cricket » October 3rd, 2020, 7:40 pm
Interference with a remote also occurred to me. A pule from someone's radar perhaps? But as best I can tell the bow thruster is hard wired. But I will check further. I am back on the boat for a few days and will leave them on to see if there is a repeat performance.
Apparently, a neighbors Hatteras 74 did the same thing a few weeks earlier.
Icango560
Vessel Info: 2004 Carver Voyager 560, 675 Volvo’s.
Postby Icango560 » October 29th, 2020, 1:52 pm
I replaced the switch at the thruster after a friends boat burned when the contacts melted. The master cut off in the bilge welded itself shut and there was nothing left do do, It might be a good idea to look at the contacts on the switch. Somewhat hard to get to but worth the effort.
Royb
Vessel Info: Carver 530 Voyager
Been thanked: 5 times
Postby Royb » June 17th, 2021, 8:17 pm
Remove and inspect the contractor at the motor, most of the time one of the contacts weld together and can be pried apart with a screwdriver. This only a temporary fix as once it happens, after separating will happen again. Interference from a remote which is rare could also be a cause.
Tbw5959
Vessel Info: 2004 466 M/V Salt and Light
Volvo TAMD75's & Kohler 20kW generator
Has thanked: 39 times
Been thanked: 4 times
Postby Tbw5959 » September 3rd, 2021, 11:19 am
Cricket,
Did you ever get this sorted out? We just had the exact same thing happen ~during sea trial~ of a prospective 466.... any ideas/insights would be appreciated, Thanks
ems05#05
Vessel Info: 2004 466 my
twin volvo tamd75
Has thanked: 5 times
Postby ems05#05 » September 11th, 2021, 9:30 am
I have a 2004 466,my thruster started on its own. It was the contacts on the dash switch. I pulled the switch and cleaned then sprayed with contact cleaner, been working fine since then.
Njlarry
Has thanked: 8 times
Postby Njlarry » December 1st, 2021, 4:07 pm
Hal? Hal? Open pod bay doors please Hal!
:captain:
