New "powerboater" joining (Montego 25)
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: New "powerboater" joining (Montego 25)
Next boat you find, get it surveyed. If the seller balks, walk away.
I'd bet money the seller knew these issues you found and was hoping someone would buy the boat and not find out until money change hands.
Move on. I believe this one may be endless headaches and may cause loss of cash itis.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- dodgingwrenches
- Vessel Info: 1990 Carver Montego 2557
- Has thanked: 2 times
buster53 wrote:Source of the post Ok, you need to walk away from this boat...and don't look back.
Honestly I don't think the seller even knows. He bought it this spring and it was his first boat. He just didn't know what to look for and didn't get a survey either (and now is buying a bigger boat). A lot of this stuff I had forgotten about since it has been a few years since I owned a boat, but some of it is new to me too (my boat didn't have A/C...)
- dodgingwrenches
You need to approach this without emotion as that often leads to purchasing something that will cost you big bucks later. I'd recommend walking away. I know there is limited inventory but don't be rushed into buying something because of that, there will be others.
Really?! Wow, that's quite a statement. I've been around boats most of my life and have been repairing them on a professional level for decades, but I would never say that I am as good as any surveyor. It's a different trade requiring very specific training. Remember, you don't know what you don't know, and what you don't know is what can come back to haunt you later.dodgingwrenches wrote:Source of the post.....Anyway brought a friend who is as good as any surveyor.....
Good luck with your search.
- buster53
dodgingwrenches wrote:Source of the postbuster53 wrote:Source of the post AC hooked up to shore water...that would probably get you kicked out of our marina...or at the least, one warning to fix it immediately. Yes, it will be expensive...haul the boat to install a thru hull, purchase a thru hull and water pump and hook up all the plumbing connections and run wiring to run the pump. Easily will run you $1000.
Forgot to add, another oddity is we couldn't find a blower switch anywhere? Saw the hoses for a blower and think all gas engines need one, but didn't find a switch and didn't hear one come on either. And the aft bilge had some water in it, but the aft bilge pump switch was repurposed for something else, so not even sure there was a switch to manually control it or check if it worked
I'm no expert, but 99.9% sure an inboard powered boat is ABYC required to have a working blower. If anything had happened to this boat and your insurance company could even remotely connect it to lack of a blower, I can see them denying your claim.
Had the boat been surveyed, this issue probably would have been the #1 critical deficiency that demanded immediate action.
