main board
mitchellp
Vessel Info: Carver 1989 38 Aft
main board
Postby mitchellp » October 19th, 2020, 7:10 am
I have a 1989 Carver 38 Aft boat, I want to change out the light bulbs on the main panel in the salon. How do you do that and what size bulbs?
Mitch
Re: main board
Postby g36 » October 19th, 2020, 8:41 am
open the panel and from behind remove the lamp veriy hole size and i would install led now you'll never have to replace them again. just note you have 12vdc and 120 volt ac dont get them confused will instgalling.
something like these .........https://www.bluesea.com/products/catego ... Voltage=12
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Re: main board
Postby Cooler » October 19th, 2020, 12:12 pm
Those are common indicator lights. Easy to find at any decent marine supply. 8-) er
Cooler By The Lake
Re: main board
Postby Viper » October 19th, 2020, 11:02 pm
The Blue Seas LED indicators won't work, they're too small for the hole. Pretty sure you're looking for 5/16" (8mm). I got green LEDs for 110V, red for the 110V polarity lamps, and yellow for the 12V side. Got them from AliExpress. Also got digital monitors to replace the analog meters. Will install next Spring.
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Re: main board
Postby ColRon » October 21st, 2020, 12:56 pm
Those look very similar to the SoLiCo lamps I replaced on my Santego. There’s a thread on here of my replacement. If you have SoLiCo lamps let me know And I can help with the part numbers.
Ron
“Escape Plan”
Murray, KY
:usa:
Return to “Electrical”
