Shore power 1 causing shore power 2 breaker to trip
- SaltyCracker
- Vessel Info: 1995 325 Aft Cabin
When this happens the load on shore power 1 is not what I would consider to be excessive, typically pulling around 15 amps.
Any suggestions of what may be causing this or where to start troubleshooting would be greatly appreciated.
- Has thanked: 602 times
Re: Shore power 1 causing shore power 2 breaker to trip
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Greg
- Been thanked: 1112 times
Do you have voltmeters for each incoming line? What do those show when you're running the house loads?
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
Shore 1 and 2 are probably sharing the same neutral bus bar and need to be isolated.
Our marina did an electrical upgrade and half the boats needed to have their neutrals separated. It was common practice in the past to share, but with the way they are required to wire docks now, this can cause problems.
- SaltyCracker
The pedestals at the marina have one 30 amp outlet and one 50 amp outlet. Shore power one is running off the 30 amp. Shore power 2 runs off the 50 amp and has a 50-30 amp adapter. I recently replaced the cables and inlets and inspect the cables regularly. The look good.
