2002 444 aft a/c shutting off- HPF code on thermostat
- 813rob
- Vessel Info: 2002 444 Carver Diesel
- Has thanked: 1 time
- Been thanked: 654 times
Re: 2002 444 aft a/c shutting off- HPF code on thermostat
You should also check the airflow and make sure there isn't a lot of lint or dust built up on a screen, filter, or the fins.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
If it failing in the heat mode, you are not moving enough air. Dirty filters, dirty coil or blocked vents.
