Need helps identifying model info for 1996 Kohler 8kW generator with Yanmar diesel
nautohm
Vessel Info: Naut Ohm
1996 455 Cockpit Motor Yacht
Twin Cummins 6CTA 8.3 w/ ZF 301 transmissions
Postby nautohm » November 7th, 2020, 10:29 am
Hi,
It has been an adventure getting my new-to-me 1996 Carver 455 mechanically sound, but it seems the major stuff has been ironed out. Now it's time for winterizing and preventative maintenance.
My 8kW Kohler generator has a Yanmar motor, but the serial number label is mostly covered with paint and I can't read it. The generator is so far running great, but the prior owner used various different replacement filters and I would like to know the OEM partnumbers so I can make sure I'm using the right stuff. I looked at cross-references for the current NAPA filters and they match multiple different Fleetguard filters...
On the label I can make out the last few numbers above "YANMAR" ---------51340
And below "YANMAR" it appears to be TS22 5B 8 I'm sure the 8 is for 8kW, and there may or may not be something between the TS22 and the 5B.
Google searches on the partial numbers didn't help. I tried cleaning the paint off with acetone and it didn't come off (at least not readily). I tried scraping but seemed like it would damage the label. I tried rubbing a pencil over paper but the paint is too thick to show.
I hope you are all well in the midst of Covid-19, be smart and stay safe!
Scott
Naut Ohm
Italy
KeithS
Vessel Info: 2005 38SS
Been thanked: 23 times
Re: Need helps identifying model info for 1996 Kohler 8kW generator with Yanmar diesel
Postby KeithS » November 7th, 2020, 12:41 pm
The Kohler 8EOZ used the Yanmar 3TNE74 engine. The Kohler oil filter is 229678 which you can cross over if you prefer.
nautohm
Postby nautohm » November 8th, 2020, 7:08 am
Thanks KeithS,
Much appreciate it.
Scott
Naut Ohm
Postby Midnightsun » November 8th, 2020, 8:55 am
This is the Fram version. https://www.fram.com/parts-search/ph6607
And here is the engine mounted fuel filter. https://www.fram.com/parts-search/C7517/
