Bulk head fabric covering
V12diablo
Vessel Info: 2001 Carver 356 Aft Cabin
Been thanked: 13 times
Postby V12diablo » November 20th, 2020, 3:54 pm
Has anyone replaced or reinstalled the fabric covering the bulkhead. Ours was loose and the insulation behind it had come off and fell to the bottom of the fabric. I peeled it off but I’m not sure what I should use for a insulation if any, prior to reinstalling the fabric, any ideas?
Jason
[image]
[/image]
quickdecision
Vessel Info: Carver 3807, 1987
Been thanked: 23 times
Re: Bulk head fabric covering
Postby quickdecision » November 20th, 2020, 10:33 pm
Use foam backed vinyl. Dry fit. The foam should be 1/4" thick. Clean area with a wire wheel to prevent transfer. The foam also helps from preventing transfer. Vacumme, then use 3M spray adhesive, on bulk head and on the foam backed vinyl. Fit on bulk head with the palm of your hand. You can peel it back up several times before it sets. Follow instructions on can. Use 3M adhesive clean up to wipe up over spray.
Ron
V12diablo
Postby V12diablo » November 21st, 2020, 7:12 am
Thanks, that is a great idea, it seems all the insulation has come loose in the forward birth, so I will be doing that for the complete front. I could use the existing fabric for patterns.
Jason
Liechtenstein
chpsk8
Has thanked: 27 times
Been thanked: 76 times
Postby chpsk8 » November 21st, 2020, 10:45 am
For the adhesive look specifically for 3M foam fast. It’s made for upholstery foam and fabric. There are other 3M spray adhesives, but that one works best.
You can also use any fabric and apply the upholstery foam to the fabric, then the wall.
Time to get creative with what you can use. It’s really not hard, just think it all the way through first.
Been thanked: 601 times
Postby tomschauer » November 21st, 2020, 5:57 pm
My wife found matching vinyl at Joann Fabrics. Use the 3m foam adhesive.
Before you replace anything, you need to find out where the water came from. Looks like you have or had a pretty good leak and some mold to eliminate.
thekylekal
Vessel Info: 1987 Carver 36 Aft Cabin
Postby thekylekal » May 17th, 2023, 11:24 pm
Hey Jason what did you end up doing with this? Thanks.
-Kyle
