Coupling alignment
- bigblockcutlass123
- Vessel Info: 1998 Carver 370 Voyager
- Been thanked: 2 times
Coupling alignment
Re: Coupling alignment
Is this a V-drive or straight-shaft?
If they are off by a bunch, or you suspect it is, then I would do it on the hard while you can. It is better to do it in the water, but it should not change a lot unless the bones of the boat are weak or the boat is blocked horribly.
Doing it now insures all the bolts and adjustments work smoothly so even if you have to do it again after it's floating you're not wasting any time when you could be boating.
- Has thanked: 603 times
You can usually tell if the boat is blocked badly by checking door fit.....does your transom door still fit the same as in the water and the sliding door work the same. Boats will relax quite a bit when floating as they are designed to be....any final adjustments should be done after the boat is floating.
Viper should have some insight on your question about the fit.
I just pulled the shafts and straighten them to .002 down the whole shaft. V Block were at or close to cutlass bearing location and shafts are less than .002 run out no matter were you check them. I just installed new cutlass bearings also.
Props are out getting tuned right now.
I would like know know if I should start jacking the motor around on the hard, or is is pointless and should wait till it's in the water?
Something I though about doing is uncoupling them and jacking the back of the boat around on the stands to see if that make a huge difference. if it does, wait, if it don't, do it now?
Before I bought this boat, I thought I read a post on somebody bitching how the hull is not ridged and they had to adjust the alignment all the time. This boat has the hollow stringers. No Wood below the water line.
After you confirm the struts are properly aligned, check the engine alignment by bringing the shaft and coupler to the transmission flange in the same centered position you had to check strut alignment. The gap between the flange and the coupler should be no more than .003" all the way around. To get to that spec, adjust the engine's position as needed to get it close to that measurement. Final check with a feeler gauge and adjustment must be done after the vessel has been in the water for at least a day.
